Old 02-22-2015, 01:24 PM   #1
Dang lp/co2 detector
I guess it is a cross we must bear with owning rv's. It doesn't seem to mater what type i have c-b-5th wheel, I can pretty much bet the co2/lp detector hates me. (As does the smoke alarm but that is another story.)
Here is my problem. I have noticed others have similar gripes but has any one figured out the problem with the detectors?
We just got a virtually new (2015) (6200mi) 24r. Everything hunkey dorie until I got it home and plugged in the shore power.
BEEP! After a few minutes. Turn off all power and let reset, turn on and a few minutes later, BEEP.
1/2 hr later. Not hooked to shore power and furnace has not been on and..... BEEP!
ARRRRGGGHHHH!
I hope someone can help.
Going to call dealer/manufacturer next week but was really hoping someone here had an insight.
Murphysmurfie is offline   Reply With Quote
Old 02-22-2015, 03:02 PM   #2
Timex's Avatar
Open some windows for a few days to air it out. I bet the fabrics are off gassing setting off the alarm. I bet the TT didn't have a battery in it when you looked at it on the dealer's lot.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 02-22-2015, 03:10 PM   #3
is there a piece of plastic over the battery connection? If you find a clear tab near the battery pull that bad boy out.
2012 Dodge Ram 2500 Limited 4x4 ramboxes
2012 Chevy Tahoe
2011 Yamaha Venture
Wildwood 241QBXL
dacheedah is offline   Reply With Quote
Old 02-22-2015, 03:24 PM   #4
Ret E-9 Anchor-clanker
donanddona's Avatar
I share your pain. My research has led me to understand "shelf life". Not that they last close to or beyond..... but their is one..
donanddona is offline   Reply With Quote
Old 02-22-2015, 03:51 PM   #5
Mikegjax's Avatar
I found mine would sound sometimes when someone was taking a shower.
Try blowing some low pressure compressed air through the front of the unit.
I don't think it is caused by battery gasses as the unit is across the coach from the steps and the battery compartment is vented to the outside.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 02-22-2015, 04:05 PM   #6
DAISY BOYKIN's Avatar
Co2 Detector
I had the same problem. I split mine up. Purchased a sealed 10yr battery operated o2 detector. I replaced the dual factory unit with just a propane detector, fit the same hole. Now, no more false BEEP, BEEP!
Got the o2 detector at Home Depot
Sid, Lois & HRH MISSY Terrible 3s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2018 60 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 02-22-2015, 05:42 PM   #7
Come On Forest River.... Old Parts in new RV's SHAME ON YOU
As I said, I purchased this RV with 6200 miles. The pervious owner put about 3500 miles on it having purchased it in DEC and then trading for another in February 15 when I bought it. He had it built with many specials and then took delivery.
Saying all that, here is the manufactured on the LP/CO2 gas detector.
Old 02-22-2015, 06:07 PM   #8
Mikegjax's Avatar
You sure that is not the manufactured date? I have not seen expiration dates on detectors, just manufactured dates. The unit should be good five years from that date.
That does not mean it is not a defective unit.
2014 Solera 24R
USN Retired
Old 02-22-2015, 06:22 PM   #9
Ashley's Avatar
Mike is Correct, that is the manufacturing date, not expiration.
2008 Dodge Ram 3500 MegaCab 6.7 Cummins
4x4, 4.10 Gears, 68RFE Trans
2012 Primetime Lacrosse 318 BHS
Ashley is offline   Reply With Quote
Old 02-22-2015, 06:32 PM   #10
ooops
ooops then It couldnt be that easy i guess...... ill edit the first post
