Originally Posted by OldCoot
That's a really simple fix and doesn't require anything from the factory. Your dealer's technician or service manager needs training. Simply extend the awning until it is just about 1/4 turn from full extension, measure from the end of the roller to the edge of the fabric. It should be within 1/8" of being the same. If it isn't, simply shift it until it is and pop rivet thru the hem on both ends.
The bottom line was that the awning may not be centered properly between the two awning arms. It's supposed to be secured to the tube after it is centered.
Thank you. I also recently found these posts, and emailed them to my service manager
Power Awning Retracting incorrectly
http://www.forestriverforums.com/for...tly-47479.html
Awning doesn't align correctly
http://www.forestriverforums.com/for...tly-47297.html
Chris
