Old 08-21-2014, 10:55 AM   #11
GM
bclemens's Avatar
Exide is the battery mfg. Not sure if they would require you to go through an RV dealer or a local distributor. A call to the dealer would be the first step if not.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 08-21-2014, 11:08 AM   #12
Herk7769's Avatar
Originally Posted by mge View Post
While dry camping, my batteries (less than 12 months old) seemed to drain fast. After a full recharge I did a controlled test at 3 amp continuous draw and both batteries were dead after 22 hours = 68 amp-hours. The batteries are supposed to be 100 amp-hours each. Does anyone know the criteria for warranty replacement? I seem to be getting less than half expected capacity.
Were the batteries in or out of the camper when you did your test?
Were they rested for 24 hours disconnected before you checked for 100% charge?
What was the rested voltage at the start of your test and the voltage at the end of your test?
What did you use to supply the 3 amp load?
HAM CALLSIGN - KC3FFW
Old 08-21-2014, 02:36 PM   #13
mge
The batteries were in the motorhome connected in parallel. I have a continuous voltage readout and can shut off the converter which charges them. I did not have a 24 hour resting voltage but the starting voltage of my test was 13.4v and 30 minutes later under-load it was 12.8v. The load was 16 LED lights in the motorhome. I stopped the test when the voltage was 10.6v under-load at 22.5 hours. The open voltage went up to ~12.4v no load. When same load again was added voltage immediately dropped to ~ 11v.
For anyone's interest: the following are the Solera incremental loads in amps
Furnace running 4.7-5.3
Water Pump running 5.3
Fantastic fan 0.9,1.1,1.3 L, M, H
Bath fan 0.7
Hood fan 0.7
Hood light 0.7
LED awning lights 1.4
Night lights 0.1
Amber door light 1.0
White outdoor working light driver's side 2.0
16 Interior LED lights 3.0
mge is offline   Reply With Quote
Old 08-21-2014, 02:44 PM   #14
vinmaker's Avatar
I agree. The batteries do tend to drain fast.
Many people buy a small generator to recharge them.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 08-21-2014, 02:59 PM   #15
Loefflerh's Avatar
where do you connect that "small generator"- directly to the batteries?
Loefflerh is offline   Reply With Quote
Old 08-21-2014, 03:02 PM   #16
vinmaker's Avatar
You simply plug the camper to the generator and have the internal inverter in the camper charge the batteries.
2015 HW296
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 08-22-2014, 06:55 AM   #17
If your dealer is like mine, he will keep your RV for a month and then tell you they did a load test and the battery holds 'a' charge ( not how much of a charge, just a charge). Therefore, no warranty replacement.
Save yourself a headache and buy a new battery.
dswiss is offline   Reply With Quote
Old 08-22-2014, 05:55 PM   #18
mge
DSWISS, I agree with you. When I asked a dealer the criteria for warranty replacement, no one seems to know. They call Forest River and they don't have a definitive answer either. I just know that the batteries installed do not and have not ever come even close to the amp-hr spec. I took the batteries into AutoZone and their "starter battery test" says the batteries are good. But without a deep cycle capacity test I don't agree. I have read that it is also common in the battery industry to overrate their batteries. However, I thought I would ask while the batteries are less than 12 months old (the replacement period). The problem appears to be that no one can determine who abused the batteries... dealer before sale or customer afterwards... and "sulfated" them (left them in a deeply discharged state too long) which is a progressive/cumulative/permanent problem for Deep Cycle batteries. They don't die, they just lose capacity. If I choose to replace them at my cost, I'll let you know if it makes a difference.
FYI, I have also determined that the Solera (and maybe others), when just parked with everything apparently turned off, including the battery switch disconnect, still draws current (0.1 to 1 amp) and the batteries will discharge over time. They need to remain on trickle charge or physically disconnected.
Old 08-22-2014, 06:23 PM   #19
Your batteries are probably not the issue. More than likely it's your converter/charger that is not giving your batteries a decent saturation charge. Most of those stock converters are pretty lousy. You would want to check with the batteries manufacturer so see what their specs are then check to see what your converter is actually feeding into them and for how long.
A programmable converter/charger is well worth the $$ if you really want to get the most out of your batteries... not to mention extending their useful life.
rana is offline   Reply With Quote
Old 08-22-2014, 06:30 PM   #20
Charge your battery, then disconnect charger. wait 24 hours before applying any load. Check voltage. It should read about 12.7 - 12.8 volts. That is the voltage of a fully charged battery. The 13.4 volts you stated in an earlier post hints at a bad battery.
Just my two cents...
2011 8314 BSS Rockwood Signature Ultralite
2005 Dodge Ram 2500 Quad-cab SLT
Makoto is offline   Reply With Quote
battery
