Old 08-22-2014, 06:33 PM   #21
And yes. Ghost draws are pretty much standard issue. Anything under 1 amp isn't too bad. Over that, I might go looking for a culprit, but without physically disconnecting your house batteries, it's just a fact of life
rana is offline   Reply With Quote
Old 08-25-2014, 08:46 AM   #22
MountainTrippers's Avatar
Deep Cycle Batteries
Originally Posted by dswiss View Post
If your dealer is like mine, he will keep your RV for a month and then tell you they did a load test and the battery holds 'a' charge ( not how much of a charge, just a charge). Therefore, no warranty replacement.
Save yourself a headache and buy a new battery.
31XHS | Trojan Battery Company These look like the best batteries I could find and they will fit without mods.
George & Karen
2014 F150 4X4 5.0L 3.55 Axle
Husky Centerline TS 1200lb 4 point WDH
2017 Rockwood Mini Lite 2109S
Palmyra,VA
MountainTrippers is offline   Reply With Quote
Old 08-25-2014, 11:26 PM   #23
mge
I did replace the batteries with two of the same rating at my cost. In a similar test, instead of 34% of rated capacity the new batteries provided over 2.5 times more AH, meeting their capacity rating, and I stopped at there. (Makoto)...you were correct, the 13.4 volt starting charge was indicative of a bad battery.
mge is offline   Reply With Quote
Old 08-26-2014, 07:29 AM   #24
Originally Posted by mge View Post
The batteries were in the motorhome connected in parallel. I have a continuous voltage readout and can shut off the converter which charges them. I did not have a 24 hour resting voltage but the starting voltage of my test was 13.4v and 30 minutes later under-load it was 12.8v. The load was 16 LED lights in the motorhome. I stopped the test when the voltage was 10.6v under-load at 22.5 hours. The open voltage went up to ~12.4v no load. When same load again was added voltage immediately dropped to ~ 11v.
For anyone's interest: the following are the Solera incremental loads in amps
Furnace running 4.7-5.3
Water Pump running 5.3
Fantastic fan 0.9,1.1,1.3 L, M, H
Bath fan 0.7
Hood fan 0.7
Hood light 0.7
LED awning lights 1.4
Night lights 0.1
Amber door light 1.0
White outdoor working light driver's side 2.0
16 Interior LED lights 3.0
Do you know if the hood, night, amber door, and white door are LED bulbs in your test. Thanks for the useful information.
Old 08-26-2014, 07:39 AM   #25
[QUOTE=Makoto;685396]Charge your battery, then disconnect charger. wait 24 hours before applying any load. Check voltage. It should read about 12.7 - 12.8 volts. That is the voltage of a fully charged battery. The 13.4 volts you stated in an earlier post hints at a bad battery.
Just my two cents...[/QUOTEl]
Try this in lieu of waiting the 24 hrs. With your meter connected, turn on some lights, that will draw off the "surface charge" that builds up on the plates, and give you a more real time reading in the instant. You will then have a more accurate reading of the batteries to see if there at full charge(12.7v).
Old 08-26-2014, 07:59 AM   #26
Witch Doctor's Avatar
[QUOTE=Still Kickin;687845]
Can you get to 13.4 reading if you are over charging the battery? Which I do know is bad but help me here how do you know it's bad because of it? Just trying to learn something here. Thanks for your answer....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-26-2014, 09:17 AM   #27
The "over charging" of the battery causes the acid in the battery to gas off, or boil in simple terms. If severe extended gassing occurs, the plates or portions of, will become exposed and thus be dead and will be unable to accept a charge. That greatly reduces the batteries life. Hope that helps. One note; most modern converters have a three stage charger, so minor gassing occurs in the process to full charge.
Old 08-26-2014, 09:44 AM   #28
mge
Answering some questions:
The range hood, amber, work light, and night lights are normal incandescent bulbs. Interesting how much better the LED lights are!
The 13.4-13.6v charge was not a result of overcharging. Even after resting for an extended period, the "surface" 13.4v charge would hold until discharging began. Also, the discharge pattern was odd compared to the new batteries. The old batteries would provide good amperage for about two hours while voltage gradually dropped from 12.6 to 11.9, then drop off quickly to 10.5v. When load taken off, voltage would again read 12.4v within seconds until load reapplied. With the new batteries the voltage drops slowly from 12.6 to 11.0v and when load is removed, the voltage only gradually increases several tenths. The literature says to never discharge lower than 10.5v in testing.
One good 100 AH battery should provide 18.9 hours @ 5 amps or 5.5 hours at 15 amps or 160 minutes at 25 amps (RC). (Interstate)
Old 08-26-2014, 08:20 PM   #29
" The literature says to never discharge lower than 10.5v in testing. " Is incorrect. 10.5v is a totally discharged battery. Never take the battery down below 50% or 12.06v. If you do you WILL severely shorten its life.
Old 08-27-2014, 04:59 AM   #30
Okay that is a correct statement, but a battery can not charge itself to 13.4 to 13.6 has to come from over charging how else would you get that kinda voltage measured?
battery
