Old 08-27-2014, 03:49 PM   #31
Originally Posted by gljurczyk View Post
Okay that is a correct statement, but a battery can not charge itself to 13.4 to 13.6 has to come from over charging how else would you get that kinda voltage measured?
The reading beyond 12.7V is a surface charge that builds up on the plates of each cell (6 in total per bat), which in cumulative, = your 13+v number. Putting a sufficient load on it, will get you back to the designed full voltage stage of 12.7V shortly there after. Not sure how else to slice it.
Old 08-28-2014, 04:15 AM   #32
Witch Doctor's Avatar
Okay thanks for the answer...
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 08-28-2014, 10:54 AM   #33
camaraderie's Avatar
Still Kickin is exactly right...batteries can READ over 13 volts after charging when their true state of charge is really 12.7 OR significantly lower.
Unless you unhook the battery from everything and WAIT 24 hours...you won't see the actual resting state voltage. A simple and cheap ($20) load tester can get you immediate results :
6 Volt/12 Volt Battery Load Tester
Of course, a real battery monitor ...not a voltmeter...makes everything crystal clear with the push of a button or two.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 08-28-2014, 12:32 PM   #34
Sandiegodoug's Avatar
When my batteries go I was told a couple of 6 volt batteries along with a roof top solar system is the ticket
Sandiegodoug is offline   Reply With Quote
Old 08-28-2014, 01:40 PM   #35
MountainTrippers's Avatar
Deep Cycle Batteries
The 12V Trojan 31Xhs deep cycle batteries have more capacity and will fit without mods. The 6V batteries are too tall to fit. See my earlier post in this thread to check them out.
George & Karen
2014 F150 4X4 5.0L 3.55 Axle
Husky Centerline TS 1200lb 4 point WDH
2017 Rockwood Mini Lite 2109S
Palmyra,VA
MountainTrippers is offline   Reply With Quote
Old 08-28-2014, 02:00 PM   #36
Thanks to you and sidekick, I just ordered one. Just never knew that, the things I learn on this site is just amazing.........
Old 08-28-2014, 09:21 PM   #37
I'll take that as a compliment calling me "sidekick". pretty good, gljoohtrykk, umm..whatever.
Glad to help.
Old 08-28-2014, 11:17 PM   #38
Glad to help.
Sorry Still Kickin, just keep still kickin...For some reason the SK brought to my mind side kick....but thanks for the lesson in 12 volt...
Old 09-20-2014, 10:43 AM   #39
Mountaintrippers
Where did you find those batteries?
tommyb is offline   Reply With Quote
Old 09-20-2014, 12:54 PM   #40
Deep cycle batteries
http://www.trojanbattery.com/pdf/dat...ata_Sheets.pdf
Here it is. They also have a list of dealers.
George & Karen
Palmyra,VA
battery
