Old 05-04-2012, 01:28 PM   #1
gb73071's Avatar
The power failed on the dometic awning on my Solera. Just got back from a two week trip. The awning failed about a week into the trip. Luckily in the stored position. I found the 15 amp fuse in the panel near the entrance step was fried. I replaced it and it was still a no go. I am still in my first year of ownership so I assume I am covered under warranty. Plan on contacting Domestic and the dealer on Monday but was hoping there is a simple fix before spending time on hold. Anyone know if there is a reset anywhere?
gb73071 is offline   Reply With Quote
Old 05-04-2012, 01:32 PM   #2
TURBS's Avatar
No other reset or breaker that I know of but I have a suggestion that you could try.
unplug motor connection at the motor then replace fuse.
if it still blows then you can eliminate the motor and narrow down your search.
on my fifth wheel where the wires from the awning enter the basement there's a connection.
then the wires are solid all the way up to the switch.
Try that.
Old 05-08-2012, 09:05 AM   #3
Hi, I have a Dometic Power Awning on my caravan in West Australia. The motor burnt out mid December 2011 and was replaced under warranty in February 2012. The replacement motor has now also burnt out! I spoke to the Dometic Warranty Agent today and he indicated that when replacing a Power Awning Motor, the operating switch should also be replaced (it wasn't with the first replacement). When the motor first failed, a check of circuit breakers & fuses didn't reveal any problems. I would be interested to learn if the operating switch is also replaced in the US when a motor fails.
Bushmann is offline   Reply With Quote
Old 05-08-2012, 01:08 PM   #4
GM
bclemens's Avatar
I would make sure you replace the operating switch, in some cases I think that's what was causing the motor issues.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 05-10-2012, 08:29 PM   #5
'79 Bonneville
Our awning motor burned out on its first use with the awning in the open position. Good thing I carry a set of tools and had the proper allen driver to remove the set screws to roll it up again to get home. The motor would click when the switch was pressed to the up or down position but no rotation. The wires smelled like they had bee cooked at the motor.
A tip: record all the numbers on the sticker on the roller near the motor before your roll the awning up manually. You will need them to order a replacement motor - otherwise your Solera may have to stay in the shop waiting for the motor to arrive.
bcunning is offline   Reply With Quote
Old 05-12-2012, 11:18 AM   #6
Recommend taking a photo with phone or camera. Can be printed out and shown to folks at parts store.
CorpusBragg is offline   Reply With Quote
Old 05-12-2012, 12:58 PM   #7
gb73071's Avatar
Thanks, I checked on the cost of the control switch and it alone is $45 so I will wait until I can get it in for warranty repair.
Old 05-12-2012, 01:28 PM   #8
Electric Awning Will Not Retract
Just took my awning motor out. Found the aluminum gear (that fits over a steel shaft) stripped.
Hoping that I can find, and buy, just the gear.
Has anyone else noticed that its impossible to find the replacement motor? Searched the awning manufacturers website with negative results. RV parts superstores with the same results.
Old 05-12-2012, 01:59 PM   #9
Herk7769's Avatar
Attachment 13666
Did you see the link I posted in the other awning thread to the used motor on eBay?
http://www.ebay.com/itm/Dometic-A-E-...item1c26e0eaf6
HAM CALLSIGN - KC3FFW
Old 05-12-2012, 03:27 PM   #10
Being the cheapskate that I am, I would get a square file and file a flat groove in the alum. wheel and fit a pc of steel stock in the groove and on the flat of the shaft. In other words make yourself a keyway. It will last a LONG time.
p.s. If the shaft has 2 flats, I would make 2 keyways.
awning
