Old 10-26-2015, 11:55 AM   #11
2012 Solera
Step Switch Mod Pictures
Originally Posted by dukeboone View Post
I'd love to see some photos of your switch sometime if you care to post them. Thanks!
Took some pictures. The switch, the magnetic switch where I tapped into its wires, and one of the screws that hold the trim strip on (with its cap removed). Believe I was able to stuff the wire I added under the black foam piece that is below the trim strip coming off the magnetic switch.
FYI, Jim
ID:	92898   Click image for larger version
ID:	92899   Click image for larger version
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 10-26-2015, 05:15 PM   #12
dukeboone's Avatar
Super, thanks for sharing the photos! Cheers!
2016 Forester MBS 2401S
dukeboone is offline   Reply With Quote
Old 11-01-2015, 03:02 PM   #13
Just use a magnet positioned close to the switch that is mounted on the door jamb.
Store it nearby when not in use.
Name:	Magent position to prevnet step operation.jpg
ID:	93462   Click image for larger version
Name:	Magent not in use.jpg
2011 Solera 235S
Freightliner Badge
cousin01 is offline   Reply With Quote
Old 11-02-2015, 08:23 PM   #14
dukeboone's Avatar
I like the magnet idea, thanks!
door
