Old 10-25-2015, 05:31 PM   #1
Door Step
I have a 2016 Solera RSLED and was wondering if anyone knows how to disable to door step when parked so it does not go in and out every time the door opens. There is also a switch located on panel above sink by fantastic fan control that I can't figure out. You would have thought the walk through would have covered it..
dogpa is offline   Reply With Quote
Old 10-25-2015, 06:19 PM   #2
2012 Solera
On our 2012 Solera "S", there are three unlabeled switches just above the entry stairs, left side when entering the coach. One of those switches effects the step operation when the coach power disconnect switch is "on" (power connected to the coach). When the step switch is "on" (the switch in ours illuminates red when "on"), the step retracts when the screen door is closed and extends when the screen door is opened. When the step switch is "off" ( not illuminated), the step stays out unless the vehicle engine is started - the step retracts when the engine is started independent of the position of the step switch and independent of the setting of the coach power switch. The step also extends when the screen door is opened "no matter what" (engine running or not, step switch on or off, coach power switch on or off). (I added a switch in series with the screen door magnetic switch so I can keep the step retracted when I open the screen door should I be parked close to a curb or in some other situation where I don't want the step to extend).
Not sure if your newer coach is the same...
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 10-25-2015, 06:23 PM   #3
I have a 2015 solera 24R. With the STEP switch(located on the left side wall of entrance) off, the step will not go in unless the engine turns on. Once the STEP switch is on, the step will move in and out every time you open and close the door.
rvcamper is offline   Reply With Quote
Old 10-25-2015, 06:26 PM   #4
Door Step
Wow found it thanks to all. Was really nice to read all of the "experience" buys from all. Made it a lot nicer sleeping on memory pad and caulking the shower wall..Thanks to all.
Old 10-25-2015, 06:28 PM   #5
If it is the switch above the sink by the entrance it is the outside speaker switch.
SSmbs is offline   Reply With Quote
Old 10-25-2015, 09:06 PM   #6
Petersb's Avatar
That switch will keep the step from going in and out.
Petersb is offline   Reply With Quote
Old 10-25-2015, 09:55 PM   #7
dukeboone's Avatar
Originally Posted by JLeising View Post
I added a switch in series with the screen door magnetic switch so I can keep the step retracted when I open the screen door should I be parked close to a curb or in some other situation where I don't want the step to extend.
JLeising, I have searched the forums for every mention you've made with regard to this switch and additional detail on the install. Doesn't appear that you've provided much more detail than the description written here in the mod thread however I'd love to see some photos of your switch sometime if you care to post them. This is certainly one thing that bugs me as I'd like to completely disengage the steps so I can first verify clearance when parallel parked. Even on the normal height curb in front of my home, if I park too close the steps will hit. Thanks!
2016 Forester MBS 2401S
dukeboone is offline   Reply With Quote
Old 10-26-2015, 12:07 AM   #8
The steps stop when they sense excess current draw. That is what stops them at there fully extended or fully retracted position. If the step contacts the curb the step stalls and else's dive current cuts off the power. So nothing to worry about. Let the circuitry do its job.
Only time I have found a need to prevent extension is if the bottom of the step could drag across the TOP of the curb and possibly jab. in that case I would be tempted to put piece of two by four between the step and the curb.
2011 Solera 235S
Freightliner Badge
cousin01 is offline   Reply With Quote
Old 10-26-2015, 12:51 AM   #9
2012 Solera
Step extension prevent switch
Don't have any pictures and the Motorhome is in the storage yard. Will try to remember to take some next time I'm over there. The description you found is quite accurate. I would add that I ran the two wires from one side of the magnetic switch up under the plastic trim on the edge of the door. I mounted the switch at a comfortable height in the same trim piece (cut a rectangular hole in the trim piece and both snapped and glued the switch in - used a switch like the light switches in the coach). Works great. As noted above, the step sliding on top of a curb is the worst issue. I also don't like the motor stalling against curbs. I look out the door window and decide whether to deploy the step if any doubt.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 10-26-2015, 01:06 AM   #10
dukeboone's Avatar
Thank for your input, I appreciate the insight. While I'm tempted to let the system work, I'm also tempted to install a switch. At least at my home the step clears the curb only when I'm parked far enough away, otherwise the bottom hits the top of the curb and looks like it will get caught up in the turf. Never actually allowed it to proceed further than just barely touching the top of the curb before promptly shutting the door. I suppose it may automatically retract if I let it go, but instinctively I just shut the door.
door
