Old 06-11-2014, 05:26 PM   #1
Door Step - Need Help
Our door step decided to stop working and I need help locating the fuse or breakers to start diagnosing the problem. There is power to the little red switch on the wall above the foot well (switch lights up when turned on). With the switch on or off the steps do not work or the orange light under the steps.
According to the manual there should be three fuse's but I can not locate them??? Any help is appreciated.
2013 Solera S
CHILL is offline   Reply With Quote
Old 06-11-2014, 06:59 PM   #2
Mikegjax's Avatar
Will the step retract when you turn the ignition on? I guess I should have asked if the step is extended or retracted.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 06-11-2014, 07:31 PM   #3
For starters, is the step stuck in or out. Get underneath it and see if the toothed gear is jammed. MAKE SURE power is OFF. IMPORTANT, it is powered independant of the coach shut off. Also inspect the shaft connected to the ball fitting for corrosion. Lubricate as necessary.
If its retracted, check the screen door switch for funtionality. Might be a malfunction there. Can't help you on the wiring schematic, or the fuse locations. Keep us in the loop.
Old 06-11-2014, 07:39 PM   #4
bubbles's Avatar
My step main power is fused directly off the battery (connected to positive terminal) via in line 25 amp fuse.
Old 06-11-2014, 07:46 PM   #5
What year Solera is yours?
Old 06-11-2014, 09:13 PM   #6
Our Solera is a 2013.
The step is in the retracted position. The door sensors are in place and appear to be undisturbed. Tomorrow I'm going to attempt in tracing out the main power line through the globs of insulation. Somewhere there should be a fuse in all that mess??
2013 Solera S
Old 06-11-2014, 10:13 PM   #7
Check for continuty at the motor, when the power is switched on. Also, try this. Move the switch back and forth a few times, you might have a bad contact in the switch. Check to see if you have power coming out of the switch going to the motor.
Old 06-17-2014, 10:00 AM   #8
mine stopped working too. was in the extended position. dealer told me that these were bad steps and they replaced it with a 'quicky' step which has been working fine ever since. if yours is in the extended position, you can disconnect the lingkage under the step and just manually push it in. secure it with a cable tie for driving around.
dswiss is offline   Reply With Quote
Old 06-17-2014, 10:45 AM   #9
bubbles's Avatar
The switchlight is only used to retract the steps. The orange step light (round under steps) only illuminates when the steps are out. The ignition interlock is for retracting the steps no matter what position the step switchlight is in. The door magnetic switch is in series or parallel (can't remember which) with the main power feed. The switchlight is in parallel with the main power feed. Suspect magnetic switch or main power feed. I think the 3 fuses are: power feed/ignition interlock/switchlight power from control center for switch bulb. Could be wrong.
Old 06-17-2014, 10:45 AM   #10
gmcnitt's Avatar
If you are underneath and the light comes on for a few seconds then goes off, its not a fuse. It is getting power...on my coach the exact thing happened. I had to remove the 5/16 screws that help the motor on and once i took that off the bind released and all was good. Re-assembled it and its been fine since. I think it sometimes goes too far and gets in a bind....at least that's what was wrong with mine.
2009 Charleston FR
Fort Worth, TX
Jeep Wrangler Toad
gmcnitt is offline   Reply With Quote
door
