Old 06-28-2014, 06:41 PM   #11
Door stop adjustment
Originally Posted by rdjjef View Post
The coach door pressure/hydraulic stop allows the door to swing open too far on our 2014 Solera. This is not a big problem unless the awning is down/extended......then door door slams into the awning arm which has chipped the paint on the door. I cannot see any way to adjust the door stop (such as the ones we have on our screen doors at home) . The stop is cylinder in shape and mounted at bottom of door. Suggestion?
Thank you
Dale
I too had the same problem after a short while of door use on my 2015 24R.
What I noticed is the door opener piston was actually loose and could be turned in a clockwise motion to tighten. This lessened the door travel to where it would no longer bump into the awning.
Gman53 is offline   Reply With Quote
Old 06-28-2014, 07:03 PM   #12
So, your saying you can spin the piston while in its fastened position, and the travel of the piston decreases. Can you explain how the adjustment process works. Thanks
Old 06-28-2014, 07:10 PM   #13
Yes, that's correct. I was able to spin the piston in a clockwise motion and hence it lessened the travel distance.
On my model, the door stop is located at the bottom of the door and is fastened to the door threshold. At the point of the threshold connection is where I "tightened" the piston by turning it clockwise.
Old 06-29-2014, 09:15 PM   #14
Thanks for all the comments and suggestions. I just moved the mounting point on the door as suggested by MikeA and that fixed it. I will take a closer look at piston closer and see if end spins clock wise and changes its range of motion.
RDJJEF
rdjjef is offline   Reply With Quote
door
