Old 07-04-2014, 11:15 AM   #91
Loefflerh's Avatar
Pedrodasdas thanks for the great pictures, no everything makes sense...off with a handful of tie-wraps.....
Loefflerh is offline   Reply With Quote
Old 07-04-2014, 11:39 AM   #92
hkreck's Avatar
I have to ask year and models of the vehicles that have had a problem? I have a 2013 Solera on a 2011-12 MB chassis. I have 18000 miles on it and have had the tires rotated once at 15000. Have not see any problems not to say their not about to happen.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 07-04-2014, 12:16 PM   #93
Send a message via Skype™ to Pedrodasdas
Mine is 2011 on a 2010 chassis sold by freightliner.
Pierrôt and Sylvie D'Astous, Solera 2011
Canada in summer, FL-TX-LO-NM-AZ in winter !
Nights camped in: 2014-96, 2015-139, 2016-89
Pedrodasdas is offline   Reply With Quote
Old 07-04-2014, 12:17 PM   #94
Loefflerh's Avatar
About the same - mine came off production line April 2013, 15000 miles no problems so far. Hub caps look identical to the pictures posted. But I am not waiting : 4 tie-wraps in place (since 10 minutes) each tire till a better solution is found
Did not take the hub caps off - I am afraid I would weaken or brake off the rivets / grips?
Old 07-04-2014, 12:57 PM   #95
Originally Posted by bclemens View Post
You are on the right path, Mike Jankowski is the correct contact. The metal braided valve extensions were given to us by the supplier (not sure who) for that particular setup. I know we use another extension called "Air Flexx" on our Ford product. I helped bring that supplier (Air -Flexx) on board based on experience with a rental account. Too many of their braided valves leaked when they became loose. With the Air-Flexx extension, it is lightweight, rigid, does not need to be secured to the rim and does not pressurize. You can cut the extension in half and it will not let air out of the tire. I cannot confirm that we have switched to that on the Solera, but I know their benefits and it seems a likely replacement.
BClemens, seems the reason has been determined. Could you move this along. Thanks
Old 07-04-2014, 01:00 PM   #96
Well, he can move this along and it will solve the double blowout issue but not the flying away liner issue :0)
Old 07-07-2014, 08:07 PM   #97
papap's Avatar
Mine is a 2010 with 20k miles. Been fighting this for a couple of years.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 07-07-2014, 08:09 PM   #98
papap's Avatar
Rivets
I just by chance notice the missing rivets. I had blow out last year. If they are not going to make liners good. I'm planning to junk them. QUOTE=Still Kickin;650389]Papap, did you discover your wheel cover failure indepedently, or was it due to his post.
We have a SERIOUS safety issue here. If Dicors' design is flawed, they need to work with FR and;
1. Reply to FR inguiry on believed cause of failure issue with Dicor supplied wheel covers.
2. Dicor needs to work with FR on corrective action in this matter.
3. Since this is a MAJOR SAFETY concern because premature wheel cover failure, can and has in several instances, may have caused tire failure, as disclosed in this forum.
4. Wheel cover detachment at highway speed, due to possible design failure, is a safety issue that might need reporting to the NHTSA.
FR should reply to this issue and advise owners of the course of action.[/QUOTE]
Old 07-08-2014, 08:42 PM   #99
I agree and mentioned in a previous post that issue as well. A wheel cover leaving a vehicle at highway speeds, as a direct result of a design failure is simply unacceptable. We await FR to adress this issue.
Old 07-09-2014, 07:49 AM   #100
GM
bclemens's Avatar
I'm not so sure the reason has been determined based on some pictures from one person. We have people on here that have had zero problems and the ones that do we have little information on.
First, I have already responded on the extensions pulling out the tire valve (post #38). If you have valve extensions that attach to the wheel liner you can contact your local dealer and they'll direct you to the best course of action.
Secondly is the issue of wheel liners coming off. We get these wheel liners from Dicor...we also buy our Sunseeker & Forester wheel liners from them as well. I don't think I've heard of s single issue with the Sunseeker and Forester wheel liners. So saying that "its the rivets" does not necessarily make it the rivets. I have contacted Dicor to look into this. I have seen Views and other Sprinters in the field and I found it odd that on used ones, some were missing the passenger side wheel liner??? Does the Sprinter wheel flex more than others? Can this unit be driven closer to curbs because it is narrower? I don't know...but we'll get Dicor to take a look.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
