I purchased my 2015 Solera 24R with 16,000 miles. Tires were okay, but I have had blowouts and will not run tires more than 5 yrs. past manufacture date. Previous owner had issues with leaking and had extenders installed along with some screw on tire pressure monitors. With centrifugal force, I could see no way these would not eventually destroy the valve stems (and also throw the wheels out of balance).
I went with the DILL TPMS system and valve stems as they have a system for the MB wheel, which has its own problems due to the shape. I now have 16,000 miles on the system. The TPMS works great and NO leaks even when sitting between seasons. Highly recommend these. Good Luck!!
Dill Air Controls
VS-3600 Sprinter Valve
SPRINTER PROBLEM SOLVED!
Makes valve stem more easily accessible
Submit
Reset
Fits 2007-2018 Dodge, Freightliner, & Mercedes Benz Sprinter DRW
Used in the outer rear steel wheel
Compatible with OEM wheel cover
Accepts 6541 flow-thru cap
Contact your DILL Distributor to purchase VS-3600 Sprinter Valves!
More
