Old 09-21-2015, 08:33 AM   #1
Petersb's Avatar
Drain
Is there only the one drain on the 24s. On the pass side for the fresh water besides the low point drains.?
Petersb is offline   Reply With Quote
Old 09-21-2015, 09:42 AM   #2
There are three water system drains on the 24S. Hot and cold low point drains left of the entry step. The fresh water tank drain tube exits just ahead of the spare tire, and the drain valve is located behind the access panel inside center of the large outside storage compartment.
Old 09-21-2015, 10:21 AM   #3
Petersb's Avatar
Thanks a lot I wanted to be shure I didn't I didn't miss one.
Old 09-22-2015, 09:17 AM   #4
Are those the two next to the generator? Will it hurt if water gets on the generator? Do you know if there is a Manual available for the 24S somewhere?
Thanks alaska6580
alaska6580 is offline   Reply With Quote
Old 09-22-2015, 09:30 AM   #5
nomad297's Avatar
Don't forget to drain the water heater.
Bruce
drain
