Old 10-26-2014, 01:28 PM   #1
Draining the fresh water
Ok new user question....on the Solera 24s where is the fresh water drain for the tank. I am assuming there is one at the low point on the tank? I have blown out All the water in the lines but I think there is still water in the tank and I want to winterize the system.
Roger64 is offline   Reply With Quote
Old 10-26-2014, 01:42 PM   #2
2012 Solera
On our 2012 the fresh water tank drain is accessed from the large rear storage compartment. There is a removable panel on the wall opposite the large (side) door. The panel is black. After removing the panel a valve is accessable (look down). The water drains out over the spare tire.
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 10-26-2014, 01:51 PM   #3
Thanks for the info , draining as I write this!
Old 10-27-2014, 08:11 AM   #4
There may also be low point drains somewhere in your system. On my 24R the low point drains are next to the coach door, just to the left of the entrance step. You may have to poke around to find them. In my case, they're two, small, end-of-pex caps that rotate to open and close.
Dave
DaveJordan is offline   Reply With Quote
drain, fresh water, water
