Old 11-14-2015, 08:08 AM   #1
Dry Camping Water Pump
Looks like my Water Pump is inop. Tried turning it on with red button light on but no noise from the pumping action. Has anyone replaced their water pump in the Solera? Did you use the same model/make that Forest River installed? Appreciate any comments-Thanks.
Capt Dan
2013 Solera "S"
FamCamp Moody AFB,GA
CaptDan is offline   Reply With Quote
Old 11-14-2015, 08:20 AM   #2
fonzie's Avatar
Check the fuse at the water pump if burnt open......
Fonzie
Old 11-14-2015, 11:23 AM   #3
MNtraveler's Avatar
Also make sure not set to winterize mode (bypass auction). Plus check adequate battery power to drive it
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 11-15-2015, 10:57 AM   #4
Ditto, there is a 10 amp fuse on the Solera water pump. Look for the fuse block near the pump, it is behind mine on the "S", ours are the skinny type, not quite like the other poster illustrated. I'd start there.
Old 11-15-2015, 01:09 PM   #5
Location of Water pump fuse
Here is a picture on mine/ Photo is taken with the walls of the passenger side cargo compartment removed.
Name:	water pump fuse.JPG
2011 Solera 235S
Freightliner Badge
cousin01 is offline   Reply With Quote
Old 11-15-2015, 09:47 PM   #6
BobHanke's Avatar
Just throwing the switch does not turn the pump on. It senses a drop in system water pressure to activate. Flush the toilet or turn on a faucet for a couple of seconds.
"Lurch" = Georgetown 2011 330TS
Jeep 2016 Cherokee
Pilot = Bob
Navigator = Xiangbing
Crew = Shikibu
BobHanke is offline   Reply With Quote
Old 11-16-2015, 05:24 AM   #7
Mikegjax's Avatar
Capt Dan
2013 Solera "S"
Had the same issue once. The check or pressure reg. valve was stuck closed. A little air pressure opened it and no further problems.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 11-16-2015, 07:51 AM   #8
Water Pump
If after all checking it is a bad pump, Harbor Freight has a replacement that connects up perfectly. I carry one as a spare and use it, plugged into my F250 trailer connector, the four prong, to pump water from a barrel into the trailer during longer dry camping periods. A spare with a very useful additional function.
JPSPete20 is offline   Reply With Quote
Old 11-16-2015, 01:48 PM   #9
FYI,
Thank You for all the inputs!! Replace the fuse and all works-Imagine That! Now just got through climbing on the roof with another problem/post. Just trying to maintain our little house and it is all more work.
CaptDan
2013 Solera "S"
Old 11-16-2015, 03:19 PM   #10
Not true on this application of the Solera. Maybe on others though.
camping, dry camping, pump, water, water pump
