Old 05-29-2016, 07:59 AM   #11
Mikegjax's Avatar
Originally Posted by Still Kickin View Post
Yep. But sometimes a situation occurs where the self priming just can't pull the long air slug along to the pump, allowing to push water
Yep. Disconnecting the inlet to the pump and allowing water to drain until air is gone will get rid of the slug.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 05-29-2016, 08:39 AM   #12
Thanks to all for your responses. I will go back to my storage facility and try to get it working. Just do not want to leave the motor running too long-might burn up. Thinking of buying an extra motor just in case I have any other problems as a backup. Thanks again!!
2013 Solera "S"
PS: See you all on the road by 15 June 2016.
CaptDan is offline   Reply With Quote
Old 06-04-2016, 03:10 PM   #13
I had the same problem with.mine after "blowing " the system out. I only use a little antifreeze to protect the pump. I had to put the winterize section of hose in a bucket, above the level of the pump and let it run for a couple minutes. Then presto, I had water in the pump and I could switch back to drawing from the tank.
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
backdoctor is offline   Reply With Quote
Old 06-07-2016, 11:21 PM   #14
MNtraveler's Avatar
Worth checking -
pump in "normal" mode, not winterize
low point drains closed
hot water tank drain closed
hot water tank pressure valve closed
hot water tank valves in normal operation mode, not bypass
filter canister properly connected
exterior hose or sprayer disconnected or closed off
exterior sink faucets closed
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
camping, dry camping, pump, water, water pump
