Old 05-28-2016, 10:07 AM   #1
Dry Camping Water Pump Problem
Just pulled my Solera out of storage and getting ready for the summer trip. Noticed when I turn on the water pump it runs and runs but their is no pressure of water coming out of the Faucets . Finally after one minute or so turn the pump off. I have over one half tank filled with water. Any ideas or thoughts of the problem appreciate it-Thanks.
CaptDan
2013 Solera "S"
CaptDan is offline   Reply With Quote
Old 05-28-2016, 11:36 AM   #2
Valve is still in antifreeze position?
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
Nights camping in 2017: 20 nights
Miles traveled in 2017: 1,530
uhduh camping is offline   Reply With Quote
Old 05-28-2016, 11:50 AM   #3
nomad297's Avatar
X2
Bruce
Old 05-28-2016, 02:28 PM   #4
DaveSchwartz's Avatar
If its not the antifreeze valve (in which case it will never self-prime), it may be that your unit just takes a long time to prime (i.e. draw water from the FW tank using vacuum caused by pumping out the air in the line).
Patience, Grasshopper: RV water pumps are built to be able to run dry like this for quite a while.
P.S. make sure you have at least a cold water faucet open when running the pump for priming... that air its sucking out of the FW-tank-to-pump line has to go somewhere.
If it doesn't prime in about 5 minutes, then you might have either a bit of debris in the pump check valve (unscrewing the pump head and cleaning manually might be necessary) or if you didn't use the pump to suck the FW tank dry (and then some) before switching the input to AF, you might have cracked a fitting in that line due to freezing water and it will suck air forever.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 05-28-2016, 10:34 PM   #5
Experienced the same thing on my last wk's trip since I didn't use the WP for a long time. It worked after 1~2 minutes with the faucet valve open. Try it again.
rvcamper
2015 Solera 24R
rvcamper is offline   Reply With Quote
Old 05-29-2016, 05:50 AM   #6
Mikegjax's Avatar
CaptDan
2013 Solera "S"
I had a similar issue and after blowning some air
through the inlet side with the outlet line disconnected it started pumping again. Either there was some debris in the pump or the check valve was stuck closed.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 05-29-2016, 06:47 AM   #7
I use the low point drain to allow the pump to prime, only because it is closer to the pump. I suppose I could also use the outside shower.
Filthy Beast is offline   Reply With Quote
Old 05-29-2016, 07:27 AM   #8
CaptDan
2013 Solera "S"
CaptDan, try this trick. Reset lever to winterize, take your garden hose (no nozzle ) butt it up to the end of the winterizing pickup hose, so as to apply a low pressure volume stream of water. Turn on a faucet, thus activating the pump circuit, and that should get enough water in the plumbing system to prime your pump. I would wrap a towel around the butt connection as you hold it, to minimize splash back.
That will charge the system with enough water to allow you to go to normal mode and get you back online.
This method works when your pump has lost prime due to no water/anti-freeze in the circuit to enable it to return to operating pressure.
Old 05-29-2016, 07:30 AM   #9
Mikegjax's Avatar
From what I understand all later model pumps are self priming if the water level in the tank is above the pumping element.
2014 Solera 24R
USN Retired
Old 05-29-2016, 07:40 AM   #10
Yep. But sometimes a situation occurs where the self priming just can't pull the long air slug along to the pump, allowing to push water
camping, dry camping, pump, water, water pump
