Old 08-25-2015, 09:37 PM   #1
FIVE2MH's Avatar
Electric Step Stopped Working
Can someone tell me what type of electric step we have in our 2015 24R, Forester? We did not receive an owner's manual anddon't know the manufacturer's name.
We are trying to trouble shoot the problem, as it has quit working - - luckily it's stuck in the closed position.
Thanks much!
2015 Forester MBS 2401R
No Toad
FIVE2MH is offline   Reply With Quote
Old 08-25-2015, 10:02 PM   #2
Pod2Vibe's Avatar
They are Lippert Components Power Steps
PH: 574-537-8900
http://lci1.com/support-coachstep
Good luck!
Pod2Vibe
2015 Solera MBS 24R - Hellwig/Sumo Equipped
TOAD: 2014 Fiat 500 Abarth
(Sold the Vibe 6506)
Pod2Vibe is offline   Reply With Quote
Old 08-25-2015, 10:19 PM   #3
FIVE2MH's Avatar
Thank you, Pod2Vibe!
No Toad
Old 08-25-2015, 10:27 PM   #4
Pod2Vibe's Avatar
You are welcome.
Keep us posted on the outcome.
Pod2Vibe
Old 08-26-2015, 08:33 AM   #5
Thanks much!
Take a peek here;
Steps not moving
I did subsequently solve my step issue after they stopped working.
Old 08-27-2015, 02:57 PM   #6
Also, see this thread for the fuse location:
Solera retractable step fuse location
Dave
DaveJordan is offline   Reply With Quote
Old 08-27-2015, 04:11 PM   #7
Usually it's not the step fuse on the Solera. Unless they redesigned it in the '14 year, there is a black box under the step, that acts as an override and stops it when the step mechanicals bind. Let me know if you can't get em going and i'll walk you through the fix, assuming thats you're problem.
Old 08-27-2015, 04:16 PM   #8
Send a message via Skype™ to Pedrodasdas
Hello FIVE2MH, is it working manually ?
Not working at all or just when you turn on the ignition ?
Pierrôt and Sylvie D'Astous, Solera 2011
Canada in summer, FL-TX-LO-NM-AZ in winter !
Nights camped in: 2014-96, 2015-139, 2016-89
Pedrodasdas is offline   Reply With Quote
Old 08-27-2015, 08:50 PM   #9
FIVE2MH's Avatar
Once again, thanks everyone for your input!
We haven't tried to work the steps manually. However, Jim just got around to taking a look today, and he did find a blown fuse, #5. Don't have a replacement. We're rolling out in the morning from this campground in Fort Smith, MT. We should be able to find one tomorrow along the way, and I'll report back as to whether that is the fix.
Now, our hot water heater isn't working! Well......at least the fishing has been good!
No Toad
Old 08-28-2015, 06:54 AM   #10
If that fuse (circuit breaker) is the long one, they appear to be hard to find. Monitor your step operation, if it occurs again, It may be a binding issue. Just sayin'
Here is a chart to help. Cooper Bussmann ® - Blade Fuses and Accessories
electric
