Old 07-14-2016, 10:14 AM   #11
Stock is 15 pound. Camping World had a 15 pound and it worse fine. $15. Mine leaked and had no resistance.
Philrisl is offline   Reply With Quote
Old 11-16-2016, 04:02 PM   #12
CharSolera's Avatar
Gas Prop Replacement - MBS Solera 24S
Can someone explain exactly how to twist off the ends to remove the existing gas prop? Mine has failed. I have purchased a replacement strut, but I cannot see how the ends "twist" off. Thank you!
Charlene
and catpanions, Purrl & Lucy Lu
2014 Solera 24S
CharSolera is offline   Reply With Quote
Old 11-16-2016, 04:42 PM   #13
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by Living_The_Dream View Post
I know it's a 20" full length 12" compressed. Just want a similar opening force as this one seems just about perfect.
The struts on my TT aren't the cheap ones you see most places. The normal struts used in automotive applications and on RVs to lift beds operate one way - they lift a given, predetermined weight. They rely on overcoming resistance or weight to operate smoothly.
Door struts are two-way. They push the door open then they dampen the swing at the end of their stroke. If you use a one-way, the door flies open and the strut bangs hard against the stops, straining the strut and the door hinges. You have to hang on to the door handle to control the opening speed. I replaced my strut with the correct one but I don't have the part number handy. IIRC, it was about $25 (plus shipping). The correct strut opens the door and slowly brings it to rest in the fully open position. I can open the door and turn it loose. The door opens quickly and smoothly then slows down as the strut extends fully.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 11-16-2016, 05:25 PM   #14
CharSolera
Lightly clamp one of the ends in to a vice or vice grip pliers. Twist the cylinder counter clockwise. If it doesn't go easy use a pliers to help it along. You will be throwing away the cylinder so do not worry about scratching it. Now do the same to the other end. A 10# strut works best for an MBS. Don't worry if you mess up the ends-you can buy them on Ebay.
2016 Sunseeker MBS W
2010 Honda CRV- SMI Stay In Play Duo
Previous-5th wheel, Class C, tent trailer, tent
SSmbs is offline   Reply With Quote
Old 11-16-2016, 05:50 PM   #15
CharSolera's Avatar
Thank you for your speedy reply, SSmbs!
Charlene
2014 Solera 24S
Old 11-16-2016, 05:55 PM   #16
You can pry the sockets off with a screwdriver and not damage anything.
Old 11-16-2016, 06:32 PM   #17
CharSolera's Avatar
Thanks, OldCoot. I'll try to unscrew them first; if that doesn't work, I'll try prying them apart. And if that doesn't work, I'm driving someplace to get help!
Charlene
2014 Solera 24S
Old 11-17-2016, 08:17 AM   #18
Mikegjax's Avatar
Some end sockets have a clip that locks them around the ball. Remove the clip
with a small screwdriver or pliers. Then the end will slip easily from the ball.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 11-18-2016, 05:53 PM   #19
CharSolera's Avatar
Job done and new door strut installed. Mikejax, good clue! There were clips which held the socket on a little ball attached to the frame and door bottom. Pry off the clips of the old strut. The new strut (held in place by the clips) just pressed into place over the balls. Yes, the door stays open! Thanks all for your guidance.
Charlene
2014 Solera 24S
Old 11-19-2016, 08:18 AM   #20
'79 Bonneville
gas strut
I got one from JR Products - SKU GSNI-5300-10 - the "10" indicates 10 pounds of opening force which is much better than the original part. The door opens more gently.
bcunning is offline   Reply With Quote
door, gas
