Old 07-12-2016, 10:59 AM   #1
Needs Help
Entry Door gas prop
One end of our gas prop has a crack and I need to replace it. Do any of you know the recommended force I should get? The part number yielded no help in a google search. 448847 0050N 134/13 B 5
I know it's a 20" full length 12" compressed. Just want a similar opening force as this one seems just about perfect.
2014 Forest River Solera 24S
Living_The_Dream is offline   Reply With Quote
Old 07-12-2016, 11:08 AM   #2
AquaMan's Avatar
The one on my GTown is 15lb and is the same size as you described. You can get just the ends though. I replaced one on the end of my prop.
2016 Georgetown 364TS
Nights Camped 2017 - 16
Old 07-12-2016, 11:18 AM   #3
https://www.shoprv.parts//online/ind...product_id=119
11 lbs
Mr Havercamp is offline   Reply With Quote
Old 07-12-2016, 11:26 AM   #4
Needs Help
Hmm, do the ends twist off? Where did you find ends? That might be so cool.
Old 07-12-2016, 11:30 AM   #5
AquaMan's Avatar
You can also check with an auto parts store, they usually have some in the trash that you can remove the end off of. M6 thread 10mm ball socket.
Old 07-12-2016, 11:35 AM   #6
Needs Help
That's a great idea! I will check with a few today.
Thanks everyone!
Old 07-12-2016, 05:28 PM   #7
Ends are replaceable. Sold on ebay.
Old 07-12-2016, 06:35 PM   #8
ilmor's Avatar
I'm going to replace mine with one of lesser force. I don't know why you'd need more the 10 lbs. Mine throws the door open too rapidly.
These things are cheap so wouldn't bother replacing ends.
http://www.easternmarine.com/gas-spring-gsni-5300-10
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 07-13-2016, 02:33 PM   #9
The MBS chassis comes with a 20# and I replaced with a 10#.
The ends twist off. You will find that many vendors sell their props with
ends too big that do not allow enough clearance with the MBS unit.
2016 Sunseeker MBS W
2010 Honda CRV- SMI Stay In Play Duo
Previous-5th wheel, Class C, tent trailer, tent
SSmbs is offline   Reply With Quote
Old 07-13-2016, 02:36 PM   #10
PS-If you need to replace the ends they are 6mm shaft and 10mm ball. On ebay.
door, gas
