11-23-2014, 04:50 PM
External Propane Gauge - not registering - again
Well the gauge is no longer functioning properly.
Filled tank today but gauge needle went the wrong way - shows empty.
I have read elsewhere that the dial gauge is removable by unsnapping it from its mount with a small screwdriver.
It looks like this might work, but I would like some input from someone that has actually removed and replaced the gauge.
2011 Solera 235S
Freightliner Badge
11-23-2014, 06:05 PM
The only input I can give is, I have a 20lbs bottle for the portable gas campfire that has a gauge. The gas place that filled my bottle said those gauges were inaccurate at best. So far, it's worked ok for me.
That's all I got.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
11-23-2014, 09:34 PM
Try this to see if it frees up. Propane Tank Gauge Sticking?
11-24-2014, 07:43 PM
Thanks Timex, but this is a built in tank in a Class C RV
Kickin - I tried the magnet but no movement.
Still want to know if I can safely pry the dial off of the mount.
Anyone?
Here is a close up of the gauge.
2011 Solera 235S
Freightliner Badge
11-24-2014, 08:08 PM
Oooo, I'm no help with that.
11-24-2014, 08:17 PM
Anyone?
Can you locate the brand off of the sensor and research the mechanism to see what drives the sensor. Post the branding info here so we can search a possible fix. Just sayin'
11-24-2014, 08:25 PM
I tapped on mine with a pair of channel locks and it unfrozen. There is a mechanical float that likes to stick. Worth a try anyways
11-24-2014, 08:56 PM
Anyone?
Will this help Propane gauge & sender - iRV2 Forums
11-24-2014, 09:09 PM
11-24-2014, 09:13 PM
11-24-2014, 10:50 PM
Thanks that must be it. It looks like its a snap on mount.
I'll try to remove it.
Just want a little encouragement!
2011 Solera 235S
Freightliner Badge
11-24-2014, 11:17 PM
It seems as long as you keep the clear plastic tabs intacked, you can pop it off. Im guessing you can buy a replacement for the 14 bucks and be back in business.
Thats assuming its not the sending unit in the tank that is the issue. Let us know how you make out, and good luck.
11-25-2014, 05:34 PM
OK. I successfully pried the dial off using two small screw drivers.
I used a magnet at the center rear of the gauge and i was able to turn the indicator.
I left it at 3/4 since i just refilled.
Now i'll have to see if it tracks consumption.
Might be a while though. 80 degrees in San Diego today.
Sorry, couldn't resist.
2011 Solera 235S
Freightliner Badge
11-25-2014, 05:41 PM
For those in snow areas - do not read.
I love our SoCal weather except for those occasional high winds. It's suppose to be 85 tomorrow in my area and 87 on Thanksgiving.
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
12-22-2014, 12:26 PM
Now i'll have to see if it tracks consumption..
It's been almost a month since I "adjusted" the pointer on the gauge. I left the refrigerator running on propane to draw down the supply. The needle didn't move at all for the longest time.
Today when I checked it the reading had moved down at least 1/8 of a tank.
It must have jumped because it didn't go down gradually; I checked it periodically.
I'll continue to monitor it for a little while. Maybe the float was stuck and now that it dropped a little it came free.
2011 Solera 235S
Freightliner Badge
