Old 11-23-2014, 03:50 PM   #1
External Propane Gauge - not registering - again
Well the gauge is no longer functioning properly.
Filled tank today but gauge needle went the wrong way - shows empty.
I have read elsewhere that the dial gauge is removable by unsnapping it from its mount with a small screwdriver.
It looks like this might work, but I would like some input from someone that has actually removed and replaced the gauge.
2011 Solera 235S
Freightliner Badge
cousin01 is offline   Reply With Quote
Old 11-23-2014, 05:05 PM   #2
Timex's Avatar
The only input I can give is, I have a 20lbs bottle for the portable gas campfire that has a gauge. The gas place that filled my bottle said those gauges were inaccurate at best. So far, it's worked ok for me.
That's all I got.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 11-23-2014, 08:34 PM   #3
Try this to see if it frees up. Propane Tank Gauge Sticking?
Old 11-24-2014, 06:43 PM   #4
Thanks Timex, but this is a built in tank in a Class C RV
Kickin - I tried the magnet but no movement.
Still want to know if I can safely pry the dial off of the mount.
Anyone?
Here is a close up of the gauge.
ID:	66819   Click image for larger version
2011 Solera 235S
Freightliner Badge
Old 11-24-2014, 07:08 PM   #5
Timex's Avatar
Oooo, I'm no help with that.
Old 11-24-2014, 07:17 PM   #6
Anyone?
Can you locate the brand off of the sensor and research the mechanism to see what drives the sensor. Post the branding info here so we can search a possible fix. Just sayin'
Old 11-24-2014, 07:25 PM   #7
Brewster McFrisk's Avatar
I tapped on mine with a pair of channel locks and it unfrozen. There is a mechanical float that likes to stick. Worth a try anyways
Brewster McFrisk is offline   Reply With Quote
Old 11-24-2014, 07:56 PM   #8
Anyone?
Will this help Propane gauge & sender - iRV2 Forums
Old 11-24-2014, 08:09 PM   #9
Gauge info Rochester TwinSite snap-on LP gauges - Google Search
Old 11-24-2014, 08:13 PM   #10
Is this it Rochester LP Gauge Snap on with Leads for Remote Read | eBay
propane
