Old 08-14-2013, 04:08 PM   #11
wmtire's Avatar
Originally Posted by cousin01 View Post
no outlet to plug the 30amp cord into as in some other RVs. On my SOLERA it cuts over automatically.
Am I understanding this correct, in you're stating there is no outlet on your Solera to plug into a 30 amp outlet?
or are we talking about something else?
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 08-14-2013, 05:02 PM   #12
I do have the 30 amp cord for connecting to shore power.
On some rigs that has to be manually connected to the generator. This is not necessary on my Solera
2011 Solera 235S
Freightliner Badge
cousin01 is offline   Reply With Quote
Old 08-14-2013, 05:07 PM   #13
wmtire's Avatar
Gotcha, that's why I asked. I was reading it to be you didn't have a way to plug your shore power cord to your Solera............at all.
It's all good now. Thanks
Old 08-14-2013, 08:18 PM   #14
Probably a breaker. 2013 with 1,000 miles must be under warranty if its something bigger. Keep us in the loop.
2012WhiteSolera is offline   Reply With Quote
Old 08-15-2013, 01:24 PM   #15
Just Arrived Canyon Lake Texas (12 hour trip), I will trouble shoot today and get back to all. Thanks for your inputs.
Dan
PS: Thank "God" I am not using the coach Air Conditioner now.
CaptDan is offline   Reply With Quote
Old 08-15-2013, 04:07 PM   #16
Dan
CaptDan, Canyon Lake is twenty miles from my house... if you're not using the air conditioner now, you're hot and sweaty!!!
tommyb is offline   Reply With Quote
Old 08-16-2013, 05:16 PM   #17
"Yes Tommyb, it is "Hot." Pretty close to the lake to take a "Dip."
FYI,
I troubleshot the RV by checking the CB's and 15 amp fuses in the box under the oven to "No Avail." Looked at the compartment at the step on the left side. I am not hooked up to shore power and my Micro wave light is still not "ON" with the back bedroom TV and Air Conditioner not working.
Checked the breaker on the generator (As per JLeising)- open the generator "service door" - After two resets it worked
"Thanks to all.
Dan
PS: Off to Kirkland AFB, New Mexico next week.
Old 08-16-2013, 08:57 PM   #18
Glad to here it was a breaker tripped. Just so we grasp all this, there is a main breakr in the generator bay service panel, that is in line with the microwave and A/C circuit that could trip, like in this instance, that will not allow that circuit to be energized when plugged into shore power. Is that a good understanding of what your problem was? Thanks for the update.
Old 08-16-2013, 09:12 PM   #19
2012 Solera
The breaker I referenced is on the generator inside the generator service panel (near the oil dipstick). It cuts off all generator output when tripped. It does not effect shore power.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 08-17-2013, 09:15 AM   #20
Ok, got it. Had Captdan plugged into shore power, he would have had full electrical capability. The issue was on generator power only, got it. Thanks.
electric, electrical
