Old 11-06-2014, 09:41 AM   #1
Mikegjax's Avatar
Fresh Water Pump
FYI, my water pump stopped pumping, but I could hear it trying to run. Waited until I got home to trouble shoot and see if I could do anything.
After removing inlet and outlet lines with the two thumb nuts on the pump, I used compressed air to blow in both lines to ensure they were open. I removed the filter screen at the pump and checked for trash of which there was a small amount that did not get to the pump. Reinstalled the screen and tried it again without success. Blew air trough the inlet side of the pump and walla, something came loose. Hooked everything back up and all is well.
Thought this little exercise might help someone that may end up with a similar problem.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 11-06-2014, 11:06 AM   #2
Taranwanderer's Avatar
So what was it that "came loose?" Something identifiable? Construction debris? Wonder how it made it through the screen...?
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 11-06-2014, 11:51 AM   #3
Mikegjax's Avatar
I believe it was construction debris, but I did not see it. I suspect small pieces getting through the screen. The main filter should have it now and that I will check at next filter change.
2014 Solera 24R
USN Retired
Old 11-06-2014, 05:16 PM   #4
My pump has lost prime twice before. I had to prime by putting water into pump inlet. Mine has small inlet screen that was removable but mounts horizontal so does not hold water. Left partial attached to feed from tank and let water drain from end then attached.
13larry is offline   Reply With Quote
Old 11-06-2014, 06:21 PM   #5
Mikegjax's Avatar
I can see the water level in the tank so I don't think mine lost prime. The level is above the pump element. Water did drain from the line when I loosened it and the inlet screen canister was full. Still an interesting idea!
2014 Solera 24R
USN Retired
pump, water, water pump
