Old 11-14-2013, 10:07 PM   #11
Originally Posted by CHILL View Post
My frig will only cool on propane. When switched over to 115 AC the compressor will not kick in, any idea's on what would be causing this?
If you have a "typical" Dometic RV refrigerator there isn't a compressor, it's an absorption system - not like residential units.
No absorption on 115 volts would be; unit unplugged (accessed at the intake grill), tripped AC breaker, fuse (in the lower control board), faulty or burned out absorber heating rod or a faulty lower control board.
The temp cut out switch OC mentions is a thermofuse. If that is tripped it would be a indication of a problem with the boiler and likely to happen when ON propane.
bgilly is offline   Reply With Quote
Old 11-14-2013, 10:17 PM   #12
Ford Idaho's Avatar
Have you put a thermometer inside to double check?
Old 11-14-2013, 10:31 PM   #13
Loefflerh's Avatar
Dumb question: is your Motorhome level? It dos not take much, like in my sons driveway it will not work on 110 - but on propane. Just asking...
Loefflerh is offline   Reply With Quote
