Old 03-09-2016, 03:42 PM   #1
Send a message via Skype™ to Pedrodasdas
Front wheel alignment specs.
Hello you all,
My Forest is now 40,000 miles and still wearing inside front tires even after two alingments.
If I remember well, somebody had posted something about not following the Sprinter specifications for the Solera.
Did I dreamed ?
Pierre. Sunbathing in Florida !
Pierrôt and Sylvie D'Astous, Solera 2011
Canada in summer, FL-TX-LO-NM-AZ in winter !
Nights camped in: 2014-96, 2015-139, 2016-89
Pedrodasdas is offline   Reply With Quote
Old 03-09-2016, 09:57 PM   #2
2012 Solera
I remembr some posts for Ford, but don't remember seeing anything similar for Sprinter. After second alignment (at a different place which had the correct machine) I went to higher tire pressure - I now use 75 psi in the fronts. Also went to Michelin tires. Now wearing quite flat on all six tires.
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
alignment, wheel
