Old 07-17-2012, 12:36 PM   #1
brania
brania's Avatar
Fuse box diagram
Today while parked at a store my 2011 Solera would not turn over. Turn key ........ Nothing , no click or anything. Odometer area flashed a wrench and the code 15 d . Mercedes could not tell me what the code meant . They did volunteer info that led me to check fuse under dash. Lower left . Fuse # 23. Is the culprit . It is a 20 amp fuse . I was told to replace it with a 25 amp . However. While rooting around I took a fuse out near bottom of box and forgot where it came from . There are numerous blank spaces near the bottom and I need help with a fuse box diagram to fill the proper space. Does anyone know where I might procure the fuse box map?
Warning. Keep fuse. # 23 in your memory bank. ..... This could save you a lot of time .
Thank you
Andy
brania is offline   Reply With Quote
Old 07-17-2012, 02:53 PM   #2
papap's Avatar
Is there not a diagram on cover of box?
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 07-18-2012, 04:39 PM   #3
I have a 2011 and the sprinter manual that came with it had a fuse diagram in it. Let me know if you need any more info and I will go get the book out of the MH.
Poppy Bill is offline   Reply With Quote
Old 09-03-2012, 03:43 PM   #4
I unhooked my tow vehicle pigtail hit bumper causing tails and clearance kites to go out can't find fuse to fix it. I have a 2012 salera.
Dxn56 is offline   Reply With Quote
Old 09-03-2012, 04:42 PM   #5
papap's Avatar
Fuse
Look behind the panel in the caparrment where sewer is at. It's at to ans you have to remove 2 screws to get to it.
Old 09-05-2012, 05:49 PM   #6
Smile
Thank you I did get the problm solved by calling fatory.
Old 09-07-2012, 12:17 PM   #7
Similar problem: All jacks are down on my 2007 Georgetown. Had a leak in one hydraulic on the left under drivers seat. Removed it, took to repair shop, fixed, and replaced. Then the hydraulic lights on panel had to be reset (pushing all four arrow buttons at same time). Jacks came up. Tried it again with a down and up - went down and would not retract. Tested slides - they went out, now will not come back in. What could the problem be? The right arrow light was on after reset but we thought that was an off level problem to do with the ground surface? Help?
skclay70 is offline   Reply With Quote
Old 09-07-2012, 03:52 PM   #8
Illucidate please!! Please share.
2011 Solera 235S
Freightliner Badge
cousin01 is offline   Reply With Quote
