Old 06-27-2013, 04:59 PM   #1
Generator with A/C and microwave on?
I was running the A/C with the propane generator and went to use the microwave and it killed the generator and wondered it that's normal .
I fired the generator back up and everything works like normal but did not want to try running these two items simultaneously again until I hear otherwise.
2013 Solera
Antiochrich is offline   Reply With Quote
Old 06-27-2013, 05:05 PM   #2
TURBS's Avatar
How many watt gennie?
Turbs
Old 06-27-2013, 05:10 PM   #3
TURBS's Avatar
Microwave approximately 13 amps
A/c approximately 12-16 amps
Converter 2-8 amps
Was water heater on?
Was fridge on ?
This chart is running amps not surge amps.
normal appliance amp draws
Old 06-27-2013, 05:15 PM   #4
Turbs
It's a 2013 with the stock 3.6KW Onan LP generator.
2013 Solera
Old 06-27-2013, 05:23 PM   #5
Converter 2-8 amps
Was fridge on ?
Attachment 34115
It looks like I might be near the top of the range with starting or surge amps added to it and not sure if I had the water pump or any lights on. I just shut off the A/C, cooked my food, and then turned the A/C back on which is somewhat inconvenient but everything was working and no blown fuses or tripped circuit breakers.
Just was wondering if others are running their A/C and microwave on at the same time?
2013 Solera
Old 06-27-2013, 05:44 PM   #6
TURBS's Avatar
If you look at my chart your gennie is right at 30 amps .
Old 06-27-2013, 05:48 PM   #7
Taylorgso's Avatar
Also, keep in mind the power output of that gen will decrease with increase in altitude. If you were in the highlands, you may have had less than the rated 30amps.
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
Taylorgso is offline   Reply With Quote
Old 06-27-2013, 08:16 PM   #8
2012 Solera
Make sure the water heater is off. On my 2012 "S" it is the third circuit breaker from the top. Top is 30 amp main, next is 15 amp microwave, then 15 amp water heater, then 15 amp for converter and some inside plugs (on back of cabover behind driver seat). If I turn off the water heater breaker (can still run water heater on propane via switch on convenience center) I have no problems running microwave and AC. Should mention I have converted lights to led.
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 06-28-2013, 01:00 PM   #9
Thanks for the replies and now I will be able to take all this into consideration when I fire up the gen.
2013 Solera
Old 06-28-2013, 05:24 PM   #10
Just for reference, the water heater default mode is LP heated water. In order to use the electric side to also heat the water, you need to remove the safety clip, that locks out the rocker switch, then turn the switch to the on position to engage the heating circuit. The switch is located in the exterior hot water heater bay. Utilizing that feature allows you to apply both LP and Electric heat element for a faster recovery. Otherwise, no draw of electric is present other than maybe a pizo ignitor for the LP, which wouldn't draw much at all.
2012WhiteSolera is offline   Reply With Quote
