Old 04-12-2015, 02:41 PM   #1
hkreck's Avatar
Glue gave in
Has anyone else had a problem with the glue on the battery cover step? I noticed last year the glue was running under the step, every time I picked it up I got glue on my hands. I took the step out today and cleaned the glue off of the metal step and the rubber cover and am now looking to use something to put them back together. should I use another glue or contact cement or liquid nails? Any Suggestions?
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 04-12-2015, 03:24 PM   #2
Might try automotive trim adhesive.
Old 04-12-2015, 07:08 PM   #3
hkreck's Avatar
Good idea that should hold up in any kind of weather and temps.
Henry & Tena
2013 Solera 24S
The Great Escape
Old 04-12-2015, 08:34 PM   #4
X2 That stuff works the best that kind of material.
Old 04-13-2015, 12:03 PM   #5
Robert Mayberry
Mine does the same thing. What did you use to clean it?
Bob
San Francisco
robertmayberry is offline   Reply With Quote
Old 04-13-2015, 12:27 PM   #6
hkreck's Avatar
I tried some paint remover first but that didn't work real good. I happened to have some spray on gum and adhesive remover which cut through it pretty good and then I washed it off with soap and water. Getting ready to try the Auto trim adhesive now. Good luck.
Henry & Tena
2013 Solera 24S
The Great Escape
Old 04-13-2015, 12:41 PM   #7
Clean with acetone first.
Old 04-15-2015, 05:34 PM   #8
Boso's Avatar
Contact cement is as good as it gets if you follow directions
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 04-15-2015, 05:52 PM   #9
Henry, that stuff works great on that type of material as it is specially formulated to adhere the rubber to most materials. I have used 3 M brand in the past on replacing a convertable top. As for contact cement, not so sure on that. I'd stick with the glue designed for that type of application. IMO
Old 04-15-2015, 06:55 PM   #10
hkreck's Avatar
I have gotten the mat glued back on with the spray adhesive seems to be working, the test will come after putting the step back in the coach and waiting to see what the different weather conditions do to it. So far so good.
Henry & Tena
2013 Solera 24S
The Great Escape
