Old 04-14-2013, 08:58 AM   #1
Solera 2013 24S
GPS in Solera
Newbie here...I am picking up my 2013 Solera s in 3 weeks. What GPS system does it come with and are you satisfied with it's peformance?
Leismom is offline   Reply With Quote
Old 04-14-2013, 09:17 AM   #2
Worked great for me on my trip from Indiana to Georgia. Still have much to learn about it. It is quick to tell you when you are over the speed limit. Was impressed with the accuracy of all side roads and exits. You will have a blast with your new Solera. Drive safe.
Trail blazer is offline   Reply With Quote
Old 04-14-2013, 09:19 AM   #3
Taylorgso's Avatar
Your Solera will come with the Magnadyne M4-LCD in-dash radio. There have apparently been some problems with this unit in the past, apparently corrected with a firmware upgrade a few months back. I have this unit in my solera (Delivered in January) and have had no problems. The GPS has a lot of nice functions. Map software is updateable only by removing the unit from the dash to access a connection in the rear, and you must partiallly disassemble the dash to gain access. The radio is wired into the TV and DVDs played on the radio are viewable on the TV. Although the radio is "Sirius/XM ready, you'll have to purchase a Sirius/XM receiver and antenna for this feature. There is a built-in connector for an iphone/ipod/ipad (using the older 30-pin connector). One problem you'll notice is the dim lighting during daylight driving: the problem is that the MB headlights come on whenever the ignition is on, and the radio is connected into the headlights and automatically dims - you have to manually go back to the home screen and change the display to brighten it. If you pull the radio to install Sirius/XM or do a firmware/map update you may consider clipping the wire which senses the headlights - then of course you'd have to manually dim the display at night.
All in all, the M4-LCD is a feature-packed unit with adequate power. I've been pleased with it in my Solera, but there have been numerous negative reviews of it on the forum.
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
Taylorgso is offline   Reply With Quote
Old 04-14-2013, 10:35 AM   #4
hkreck's Avatar
I have a Magnadyne in my Solera and the problem I had last year was it would shut down on me just at a time when I really needed it. I take my Garmin along now for GPS and just use the Magnadyne for the other features on it.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 04-14-2013, 12:17 PM   #5
Solera 2013 24S
Does the garmin have any special features that would warn you about low height tunnels and other places that the RV should not go?
Old 04-14-2013, 01:10 PM   #6
hkreck's Avatar
My nuvi 255W version does I keep it updated on a regular basis.
Henry & Tena
2013 Solera 24S
The Great Escape
Old 04-14-2013, 06:34 PM   #7
Could you elaborate further on the firmware update. Specifically on how and where the update is added. Thanks
2012WhiteSolera is offline   Reply With Quote
Old 04-14-2013, 07:26 PM   #8
hkreck's Avatar
I took the SD card out of the unit and put it into my computer, went through the update process and received a message stating that the unit and software were up to date. If you know any thing else on the matter I'd appreciate the help.
Henry & Tena
2013 Solera 24S
The Great Escape
Old 04-14-2013, 11:03 PM   #9
GM
bclemens's Avatar
Well said Taylorgso...that saved me a lot of typing. I rarely use the GPS portion, because I have TomTom on my iPhone..but lately I've been using Google Maps on my iPhone with turn by turn directions. It is sooooo much faster than any nav unit I've used.
With most (if not all nav units) you have to type in the address...number, city, state. Or navigate to a POI.
Google maps...you basically do a google search for what you want...it searches, then you just hit the "Car" icon and it will give you route options and everything. Pretty slick I must say.
There is a ton that the M4 can do...it just whether you want it to. One of my favorite features is to connect your bluetooth enabled phone for hands free calling...if your phone has music...just hit play and it will stream the music via bluetooth. So you don't need to use the iPod dock. I prefer to use the phones music controls over the M4 on screen display.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 04-15-2013, 07:42 PM   #10
hkreck's Avatar
I decided to try to update my SD card yesterday, after running it through the update which came back again stating that my software was up to date. BUT when I put it back into the unit and ran the navigation system I got a message stating that the software was out of date. I don't get it?
Henry & Tena
2013 Solera 24S
The Great Escape
