Old 11-12-2015, 10:35 PM   #1
Gps voice
Has anyone had problems with getting the GPS voice activated? Mine breaks into the radio but no voice. Is brand new, is this an inherent problem?
dogpa
dogpa is offline   Reply With Quote
Old 11-12-2015, 11:14 PM   #2
Farkasb's Avatar
You can try adjusting the voice volume, if you haven't already. The default is volume is quite low.
Next I would try resetting the radio with a paper clip or pen tip. There's a small rest button just under the main powder button.
Here's another discussion on this topic: http://Jensen 7020 navigation http:/...ad.php?t=95328
2016 Forester 2401WS
Farkasb is offline   Reply With Quote
Old 11-12-2015, 11:25 PM   #3
Thanks I will try the paper clip first and the volume knob next then I guess off to the dealer.
Old 11-12-2015, 11:39 PM   #4
If you've got a Jensen VM9726 (standard with at least some of the 2015 Soleras), the system has a whole variety of ways to set the volume, including setting it based on the source of the sound (radio, navigation, blue tooth, etc.) I'd strongly suggest looking at the manuals (both the basic VM9726 manual and the navigation-specific manual) to figure out the various menu options to check and set volume.
The Jensen VM9726BT web site is here:
Jensen : Mobile Multimedia : VM9726BT
That page has a section "Support/Manuals" with links to both the basic manual and the navigation manual.
Dave
DaveJordan is offline   Reply With Quote
Old 11-13-2015, 09:59 AM   #5
dogpa
Try resetting it with the hole in front with a paper clip. Worked for mine
Sent from my SM-N910V using Tapatalk
hifromkate is offline   Reply With Quote
Old 11-13-2015, 12:55 PM   #6
We have the VX7020a and had to go to the Jensen website and download the latest software update in order to get the voice to work. You have to take the mini SD chip out of the unit and plug into a windows computer for the download. It is a big file and took all night to download.
Good luck,
Larry
Chief4774 is offline   Reply With Quote
