Old 07-28-2015, 12:57 PM   #1
hkreck's Avatar
Hard wired 30 amp
I have a Solera 24S which has it's 30 amp cord hardwired in the rig. I'm thinking of replacing it with a 30 amp inlet plug and a detachable cord. Has anyone else looked at doing this or maybe done it?
Henry & Tena
hkreck is offline   Reply With Quote
Old 07-28-2015, 02:35 PM   #2
VinceU's Avatar
Not sure the advantage to you but one certain disadvantage
Is one more potable joint which overheats when conducting 30 amps of current. The forum has tons of cases of these junctions getting hot when full current is drawn just below circuit breaker rating. It's happened to many of us.
Old 07-28-2015, 02:55 PM   #3
Broadway Joe's Avatar
Plus you run the risk of leaving your rig unattended and tempting some "poor" soul from easily freeing it for profit. LOL
Broadway Joe is offline   Reply With Quote
Old 07-28-2015, 03:01 PM   #4
itch'n to road trip
campnqueen's Avatar
Send a message via AIM to campnqueen Send a message via MSN to campnqueen Send a message via Yahoo to campnqueen
We have the in wall hard mounted 30 amp inlet.
Advantage, one less place for mice to get in.
Look for the straight blade style.
We have the turn and lock. One of the prongs is loose and now we have to change it out.
Conntek has some good ones and codes to match.
2012 Ford F-250 King Ranch Super Crew Cab 4x4
2014 Work & Play 25ULA
Paula Drake, Ken Cooksey, Sunny Delight, Valor & Scarlet Begonia
Jasper Ga.
campnqueen is offline   Reply With Quote
Old 07-28-2015, 03:05 PM   #5
hkreck's Avatar
Good responses on the subject, I would be looking at having the plug in, inside of the compartment ratter than outside where it could be taken. And I have been looking at the Smartplug 30 amp connection, which doesn't turn to lock and has a internal heat sensor to prevent over heating problems. Just what I've been thinking about also.
Henry & Tena
Old 07-28-2015, 03:17 PM   #6
Ecopco's Avatar
One additional advantage of having the one that you manually attach is that you can get a second 30 amp cord and leave one in the MH and keep one attached to the outlet where you keep your motorhome (if security permits).
2015 Solera 24R
The Peterson Family
Southeast Louisiana
2015 Solera 24R
Living our dreams one day at a time!
Ecopco is offline   Reply With Quote
Old 07-29-2015, 12:08 PM   #7
If purchasing new hardware, consider products from Marinco - they make electrical components for both the RV and Marine industries. Also, I've noticed that most expensive RVs use a separate cable that connects to a hard mounted receptacle on the side of the camper.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 07-29-2015, 01:16 PM   #8
MilCop4523's Avatar
Originally Posted by DickiedooFlagman View Post
If purchasing new hardware, consider products from Marino - they make electrical components for both the RV and Marine industries. Aclso, I've noticed that most expensive RVs use a separate cable that connects to a hard mounted receptacle on the side of the camper.
I had one on our 2012 Salem 27RKSS and it worked perfectly. no struggle to reinsert the line into the trailer at 4 or 5 degrees.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 07-30-2015, 08:46 AM   #9
Wolverine 1945's Avatar
The detachable one is sure a lot easier to deal with !!!
But maybe not as secure as the hard wired one !!!
Wolverine 1945 is offline   Reply With Quote
Old 07-30-2015, 09:37 AM   #10
hkreck's Avatar
As I stated, I'm locating the plug inside of the compartment so it'll be secure from theft. The plug I'm going with is the 30 amp SmartPlug . The design was made for the boating industry and has found it's way into the RV field. Their web site is SmartPlug.com, their a little more expensive than the regular plugs but look a lot more safer.
Henry & Tena
Old 08-01-2015, 09:34 AM   #11
VinceU's Avatar
As I stated, I'm locating the plug inside of the compartment so it'll be secure from theft. The plug I'm going with is the 30 amp SmartPlug . The design was made for the boating industry and has found it's way into the RV field. Their web site is SmartPlug.com, their a little more expensive than regular plugs but look a lot more safer.
Good idea, does it trip and warn or just warn?
Old 08-01-2015, 09:48 AM   #12
hkreck's Avatar
The way I understand it they trip at 200 degree, then reset once the temp goes back down to 120 degree. They have video of these on youtube and their web site at smartplug.com.
Henry & Tena
