Old 05-19-2015, 01:06 PM   #11
If it's not too much trouble I might disconnect a battery cable if you do not have a disconnect switch. Not worried about getting shocked but shorting out something on the DC side accidentally while moving things around back there.
2014 Windjammer 3025W Diamond 34.5 ft 8300 lbs.
2010 F150 SC XLT 4x4 5.4L, 3.55 gears 20" rims
12 k Equalizer WDH, Firestone Airbags, HD Bilsteins
TST 507RV TPMS
Zolin is offline   Reply With Quote
Old 05-20-2015, 07:49 AM   #12
Anyone know if there are wiring diagrams available for the distribution center on 2015 Solera 24R
HossHogRV is offline   Reply With Quote
Old 05-20-2015, 11:32 AM   #13
Sometimes the wiring diagram is located on the inverter itself. When you pull the inverter/power box from the wall and slide it forward you sometimes will see it right there. My diagram is on back the cover plate. Just remove the screws, detach, and flip over.
TST 507RV TPMS
Old 05-20-2015, 11:39 AM   #14
TURBS's Avatar
Out of curiosity why do you need a wiring diagram?
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "6 nights"
Old 05-20-2015, 01:57 PM   #15
The progressive industries EMS HW30C comes with diagram and instructions. Simply find the power supply cord and follow the instructions. Really quite simple. If you are unsure find an experienced or qualified technician to install it for you. If you are installing a Progressive Industries product they have technicians to provide support also.
TST 507RV TPMS
Old 05-21-2015, 05:07 AM   #16
TURBS
There are a few wires and wanted to make sure I knew which was the main coming in. Perhaps it will be obvious once I take a look.
Old 05-21-2015, 06:13 AM   #17
TURBS's Avatar
It'll be obvious.
They'll go to your main on your distribution center.
Id pull the incoming wires out of the distribution center and put them on the "in" side of the surge then run new from surge "out" back to distribution center.
TURBS
Old 05-22-2015, 08:29 AM   #18
Did a quick look behind the distribution center and agree a nice fit for the surge protector. Hope to get time tomorrow to install. Thanks for everyone's input.
Wanted to get bclemens input first to see if there is a junction box accessible elsewhere closer to the outside shore power connector. Perhaps the main runs directly from the outside connector to the distro center?
Old 05-23-2015, 12:51 PM   #19
Installation under stove behind distribution center was easy. I removed the Orange 10/2 wire from the 30 amp main. I used this as input to surge protector. Purchase 2 foot of 10/2 from Lowes. I connect one side to output of surge and the other to the distribution center where I had previously disconnected.
I was unable to connect the remote display because the cable was missing. Called tech support and found out that the surge protector functions in protect mode without it. I applied power and the RV powered on as expected.
Will install remote monitor once new cable arrives.
Thank for the help. This was a bit out of my comfort zone but in retrospect not that difficult.
Old 07-11-2015, 03:50 PM   #20
Karen, Pete & Chloe Kat
sanpedroflyer's Avatar
solera 2015 wiring diagrams
Bryan Clement recently posted these wiring diagrams!
sanpedroflyer is offline   Reply With Quote
