Old 03-26-2016, 07:02 PM   #1
Has Anyone Installed The Winegard Rayzar Antenna ?
My RV has the Winegard Crank-up antenna, so I was thinking about replacing it with the King Black Jack because of its obvious benefits. While investigating, I stumbled upon the Winegard Rayzar. Of course it is much more expensive, but I like the concept, and it is very low-profile, which I like because tree branches at a campground won't break it off.
Does anyone have a Rayzar, and if so, what do you think about it ?
Thanks !
nusslejj is offline   Reply With Quote
Old 03-26-2016, 10:41 PM   #2
SilhouettePenny's Avatar
My Rayzar does pick up more channels and you only have to rotate it half way because it picks up signals on both sides. While you're up there be sure to pull off the little black rubber cap and squirt lube in the elevation gear housing, really makes a difference.
2017 F350 Dually 6.7 Diesel
2014 Silhouette 299 RKDS
Nights Camped 2017 - 63
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 03-27-2016, 06:54 AM   #3
There may be more than one product named Rayzar The one I'm looking at is a 15" round dish that just screws down to the roof. Inside is an antenna and a motor that swings it around looking for the best signal. There are no cranks or anything manual you have to do - it is all automatic. However, it is pretty pricey.
antenna, led, winegard
