I have the same problem.
Here is what I tried and here is what I found.
First I tried to extend the depth of the strike with some "JB Weld" epoxy. This was intended to increase the overlap between strik and latch. I did it in two applications to build up the strike.
I installed the latch but with only two screws to test things and it seemed to hold.
Then I installed the other two screws and tightened all the screws. But when I tried the latch it once again failed to hold.
When I went to disassemble it again I noticed that the latch was not fully extended until the screws were backed off a little. Now with the screws "less tight" the latch extends fully and the compartment stays closed.
I am not completely through with this as I want to find out what binds the latch when the screws are fully tightened, but it will do for now.
