05-31-2014, 03:35 PM
Headlight fuse ?
I just notice my right headlight is not working.
Is there a fuse somewhere ? All my other vehicles had fuses for the headlight !!!!
Pierrôt and Sylvie D'Astous, Solera 2011
38 on 50 states, 9 on 10 provinces.
05-31-2014, 04:03 PM
2012 Solera
Check the bulb. They burn out regularly as they are on all the time (as Daylight Running Lights). If a fuse, I would expect both to be out.
JLeising
2012 Solera "S"
Calif SF Bay Area
05-31-2014, 07:55 PM
If just one headlight is out then I'd have to say the bulb is out, a blown fuse should take out both headlights.
Henry & Tena
05-31-2014, 08:05 PM
Most headlights are on automatic breakers, not fuses as a safety feature.
Start carrying spare bulbs.
06-01-2014, 09:49 PM
Both of mine went out at roughly the same time. Check the bulbs before you dig any deeper.
2011 Solera 235S
Freightliner Badge
06-01-2014, 09:54 PM
Headlamps are not fused they have a resetting circuit breaker.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
06-01-2014, 09:56 PM
It is most likely your bulb. It is also not to uncommon that the other bulb will blow in short order due to the increase in unblanced load, when you switch the headlights on.
06-03-2014, 09:23 PM
Headlight fuse ?
Vehicles have a driver and passenger headlight fuse. So if a fuse were to blow at night then you would still have another light. If they were on the same you would be driving in the dark with no lights at all
06-03-2014, 09:39 PM
Sorry sir, but you are mistaken, headlights are on automatic resettable breakers. There are no fuses on the headlights.
06-04-2014, 05:30 AM
I guess you never looked in the fuse box of any of your vehicles because the driver and passenger are on separate circuits. So you are driving without headlights.
06-04-2014, 06:00 AM
All Vehicle headlights are protected with circuit breakers instead of fuses because, when light bulbs fail, there is an ionizing arc internally that causes high current. You see that at home - when a light bulb fails you see an instant of very bright light. This pulse of high current can blow a fuse. It also can trip a circuit breaker, but the circuit breaker is designed to reclose while, once a fuse is blown, it stays blown. Headlights are a critical safety device. It is better to attempt automatic reclosure following a fault, than it is to leave the headlights off, in case the fault was temporary. Most are built into the light switch itself.
06-04-2014, 06:06 AM
Here ya go, find it for the guy. NCV3 Sprinter Fuse Block layouts
