Old 11-29-2012, 08:01 AM   #1
papap's Avatar
Heat
For some reason when I turn on heater. The AC blower also comes on. Is it suppose to do this??? Never had any other camper to this before.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 11-29-2012, 08:25 AM   #2
papap's Avatar
I ended up just turning the AC breaker off.
Old 11-29-2012, 09:03 AM   #3
TURBS's Avatar
Was the fan switch on or on auto ?
Old 11-29-2012, 09:29 AM   #4
papap's Avatar
My thermostat only has fan, cool and furnace Also on and off.
Old 11-29-2012, 10:23 AM   #5
When you push on /of switch make sure it says auto (AUT) and then push button till it says heat.
kelly72
2113 Solera 24R
kelly72 is offline   Reply With Quote
Old 11-29-2012, 10:41 AM   #6
papap's Avatar
Mine does not give you an auto choice. Only 4. Fan, cool, furnace and off. Also plus or minus to adjust temp.
Old 11-29-2012, 11:00 AM   #7
2012 Solera
Choose fan. Then hit + or - to set to auto. Then choose heat.
JLeising is offline   Reply With Quote
Old 11-29-2012, 11:03 AM   #8
VinceU's Avatar
+ - sets fan speed and auto when fan is first selected.
Old 11-29-2012, 11:51 AM   #9
papap's Avatar
Thanks. That hot it. Never had a Manuel and never used heat I guess. LOL
Old 11-29-2012, 08:41 PM   #10
Could you please go step by step to turn on the heat, without effecting the a/c system. I wasn't quit clear on the post.
2012WhiteSolera is offline   Reply With Quote
Old 11-29-2012, 09:05 PM   #11
2012 Solera
What I do - (2012 Solera "S"):
1) Ensure 12 volts is turned "on" to RV (switch next to stairs).
2) Turn on propane (knob in propane compartment opened fully).
3) Confirm propane "on" by lighting a stove burner or two.
4) press button on thermostat to select "fan". Press + or - to select "auto".
5) press button on thermostat to select "heat". Press + or - to select desired temperature.
Thats all - if the furnace doesn't start, try setting the thermostat to a higher temp.
Old 11-29-2012, 09:05 PM   #12
VinceU's Avatar
Select "fan" with lower control button
while in fan use + or - to change to auto or low.
Use bottom button again move down to "furnace" for heat
Use plus and minus for temp setting.
Furnace starts and in "Auto" overhead fan will not run.
