Old 08-21-2013, 12:24 PM   #111
Just installed mine this morning. Took about 2 hours start to finish. I used my floor jack to raise the Hellwig bar into position then it was a simple bolt on. My parts kit was dated 7-30-13 and the correct bolts were supplied. The problem of the wrong bolts being sent with the sway bars looks to have been corrected.
Took a quick 20 mile drive down some back roads and my first impression is that the chassis feels firmer and more controlled.
We are leaving tomorrow for a trip around Lake Superior so I am looking forward to seeing how it handles fully loaded.
Thanks to all the Forum members who gave us the benefit of their experience and advice about the Hellwig sway bar upgrade.
Winger is offline   Reply With Quote
Old 08-21-2013, 01:27 PM   #112
OK,folks, I'm convinced and am arranging to have a Hellwig sway bar ordered and installed on our 2013 Solera. However, there is one thing i'm not sure about. Most of the comments on this thread appear to refer to a sway bar that would be mounted at the rear axle - the 7524, I believe. Though early on in the thread, a couple people mentioned installation of sway bars (plural). Also, the two videos attached to one comment, addressed installation of rear and front sway bars (though the videos applied to a Ford class C). So, is there also a Hellwig sway bar for the front end of the Solera and if so, has anyone tried one and have an opinion about it?
Chris Weller is offline   Reply With Quote
Old 08-21-2013, 01:31 PM   #113
Oops. Sorry, I meant "7254" not "7524".
Old 08-21-2013, 03:37 PM   #114
I just installed the one ... in the back. I don't know about a front one. The one in the back is all that is needed in my opinion.
DebbieMH is offline   Reply With Quote
Old 08-22-2013, 10:28 AM   #115
Thanks, Debbie. Just wanted to make sure I hadn't missed part of the picture. We're about to start a long trek and i'm hoping to avoid a repeat of the "white knuckled" driving experience we had across the desert and through strong gusty winds for a couple days in southern Utah & northern Arizona last spring, Sure sounds like the 7254 sway bar will help. I'm having it installed next week, I much appreciate the information and encouragement you and others have provided on this thread.
Old 08-22-2013, 10:32 AM   #116
Chris - you will find that it is a tremendous help with the wind - you can still get pushed around some, but it takes a much stronger wind to do it. I now drive one handed most of the time .... just like a car. Have fun on your "trek" and let us know what you think!
Old 08-22-2013, 11:12 AM   #117
Northern Most Member ?
Toolman Taylor's Avatar
For those that want even more sway prevention......
an Auxiliary Rear Sway Bar Kit for the rear or in afterwords a second sway bar in front of the rear axle
Sway Bar
Tim + Denise Taylor
Denali Park Alaska
2013 Solera 24R
Toolman Taylor is offline   Reply With Quote
Old 08-22-2013, 07:22 PM   #118
hkreck's Avatar
Man that looks like it get pretty close to that drive shaft? I'm afraid the $600 plus price range is a little more than I'd want to go considering the one I put on is doing a great job as it is.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 08-23-2013, 04:25 PM   #119
Luvnlife's Avatar
Sitting in Petoskey Campgounds on Lake Michigan. We finished a nice trip from San Diego to Michigan. A huge difference from the last trip to South Carolina. There is a noticeable difference with Hellwig sway bar installed. Handles better when passed by big trucks or in cross winds. The final test will be the return trip when we are bound to hit some headwinds. I think this was a great purchase.
Luvnlife
Larry and Mary
Solera R 2013
Luvnlife is offline   Reply With Quote
Old 08-23-2013, 05:06 PM   #120
Taylorgso's Avatar
Larry/Mary:
It does make a huge difference. I installed mine a couple months ago, but only have about 500 miles since the install. Big test next month when we leave NC for PA and then to SD. Mountains, Plains, rolling hills, etc. and probably a fair share of cross winds. I'm guessing a comfortable trip with the Hellwig, though I admit we never took it on an extended trip before the installation.
Someone has proposed a second rear sway bar for the Solera. Interesting read, and I'm waiting for someone else to bite the bullet first. At $675 I'm not sure I'd make that purchase without knowing more. Looks like a fairly complicated install, and I'm not sure drilling into the frame wouldn't affect the MB warranty. Also, it it flattens out the ride too much, it may take too much of the road feel out of the ride. With a high center of gravity as in these rigs, I'd want to feel some sway on curves/off ramps, etc... Heaven forbid rolling it over because I didn't sense the sway at all - although my driving style would put me at low risk for that!!!
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
Taylorgso is offline   Reply With Quote
