Old 08-23-2013, 08:04 PM   #121
I'm happy with the one as well. I don't think a second one would help much.
DebbieMH is offline   Reply With Quote
Old 09-03-2013, 06:20 PM   #122
MountainTrippers's Avatar
Just jumping in here. We just got our Solera 24M last month. After seeing this thread I ordered my sway bar today. On the shocks, Is the correct bilsein part# 24-157161. This is just great stuff! My wife and I have been camping for 30Yrs in just about everything But,this is our first MH. Have not named it yet maybe Dream Weaver What do you think.
George & Karen
2014 F150 4X4 5.0L 3.55 Axle
Husky Centerline TS 1200lb 4 point WDH
2017 Rockwood Mini Lite 2109S
Palmyra,VA
MountainTrippers is offline   Reply With Quote
Old 09-03-2013, 08:58 PM   #123
We only did the sway bar - great. Others have done both, so they will need to answer your shocks question. BTW love the name Dream Weaver - seems quite appropriate!
Old 10-02-2013, 08:43 PM   #124
Can someone tell me the diameter of the Hellwig or the OEM sway bar? I have a used 24M would hate to order one and then find out that it had already been changed.
pinkstonj is offline   Reply With Quote
Old 10-02-2013, 09:19 PM   #125
2012 Solera
Not sure of diameter but noted that the Hellwig uses Allen head bolts to attach its brackets to the axle housing; the stock sway bar uses standard hex head bolts.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 10-02-2013, 09:44 PM   #126
2012 Solera 24S
I still had the OEM sitting in the garage, it's a little over 1". Hellwig is significantly larger.
Nats is online now   Reply With Quote
Old 10-06-2013, 12:59 AM   #127
Installed 2 years ago on my 2011, have put about 35k mi since. An excellent addition. Parking lot exits & crosswinds tolerable.
WARNING:Instructions say to re-torque bolts after awhile (can't remember exactly), I didn't & the bolt backed out of the U bracket top left in Washington state, big bang. Had a mechanic look at it & I got under as well. Bracket bent all the way down, but drivable. Made it home to LA, safely, taking it real easy. Pain in the drain fixing because it screwed up the threads on the weld nut as it exited. I bought bolts about 1/4" longer, 8mm if I remember, now bites the whole nut.
BE SURE TO RE-TORQUE THE BOLTS.
If anyone finds a front axle sway bar for this chassis, post the info. I think it would help more than a second on the rear.
peterfinurke is offline   Reply With Quote
Old 10-06-2013, 05:37 PM   #128
Taylorgso's Avatar
Which poses the question about the Loctite? If I re-torque the bolts, is the Loctite that was applied no longer effective, or does it continue to work even if the bolt is turned? Or, do I need to remove the boltl, re-dress it with Loctite, then re-install and re-torque? Not familiar with how the Loctite stuff works.
I just finished a 4000 mile trip, and probably do need to check the torque on those bolts! I'll do that as soon as I remove all the bugs I collected
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
Taylorgso is offline   Reply With Quote
Old 10-06-2013, 08:26 PM   #129
2012 Solera
Pretty sure if you turn the bolt the Loctite hold is history. I just checked mine with a ratchet - all felt tight - did not "re-torque" as that would likely break the Loctite loose.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 10-06-2013, 08:48 PM   #130
Taylorgso's Avatar
Curiosity got the best of me, so I went to the Loctite web site. Apparently, once set and cured, it must be heated to 500 to loosen. So if it's not loose with the ratchet, it's probably not loose at all!
Greensboro, NC
