Old 02-23-2014, 03:55 PM   #161
What size are the original bolts?
I need to remove the old bar. I don't have a socket that fits. 17mm is too small. Is it an 18mm? Don't want to buy too many unnecessary tools.
TIA
tommyb is online now   Reply With Quote
Old 03-11-2014, 06:31 PM   #162
Need the sway bar for sure. After driving 1500 miles during the past month, wind and trucks sure affect the drive. I'm sold on the Helwig sway bar but don't find that the 7254 that others have used, fits my 2014 FR 24R. Does anyone know if the 7254 does fit or another one? Please advise.
richhop25 is offline   Reply With Quote
Old 03-11-2014, 06:55 PM   #163
If I remember it's 19mm. The Helwig bar is much larger than the original equipment & made a big difference in my unit. Well worth the $150.
NOTE: Instructions say to re-torque the bolts after driving it awhile, I didn't & it spit out a bolt in Washington State last summer. Had to clean up the threads & spend a day fixing. RE-TORQUE the bolts as instructed, save some blood, sweat & tears.
peterfinurke is offline   Reply With Quote
Old 03-12-2014, 09:00 AM   #164
Thanks peterfinurke, for your reply. I'll certainly re-torque as you suggest.
Allow me to clarify my question about which sway bar to get. I have a 2014 FR 24R. That is a 2014 MB chassis with the class C home on it. Searching the usual places provided here, I cannot find that any of them provide or mate my chassis to this or any sway bar. Perhaps it is too early for them to have the match in their databases.
Has anyone mated this sway bar to the 2014 chassis??
Old 03-12-2014, 11:57 AM   #165
2012 Solera
I have a 2012 Sprinter so can't answer your question. Suggest you contact Hellwig directly - they were quite responsive when I encountered a bolt issue with my sway bar. Contact Us | Hellwig Products
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 03-31-2014, 12:09 AM   #166
Installed the Hellwig - 2 questions remain
I got the sway bar installed. I had to buy a different torque wrench. My old one was a bar with a loooong pointer and no ratcheting action. I couldn't maneuver it in the space required, or even see the scale and pointer. Had to buy one from home depot - only $20, clicks when correct torque reached, and ratcheting action. Made the job much easier.
Two questions remain. The old swaybar is bent so it sits in one plane. The replacement has the center "u" slightly out of plane. Anyone know whether this should go up or down? The photo is terrible, and impossible to tell. I installed it down... don't see how it would make a difference, but still want to know.
Second, the bolt at the aft end of the passenger side looks like it just might just rub a hole in the exhaust pipe. Doesn't touch, but so close I fear that it will rub when on the road. Not enough clearance to insert bolt from the other direction. Those bolts must be hardened. Does anyone know where to get one about 1/2" shorter? Or would it affect the hardening of the steel if I cut 1/2" off?
Any thoughts?
Thanks,
Tom
Old 04-27-2014, 10:10 AM   #167
Finally installed the sway bar. I purchased it late August last year and soon after got in a motorcycle wreck with a long rehab. It was still a pretty hard job as my right arm/shoulder are still recovering but it's done and is a big improvement from the little driving I have done so far.
The instructions are decent but did not say where to put the supplied loc-tite. I put mine on the 4 screws that hold the bushing brackets to the axle but now think perhaps it is supposed to be used on the strut bolts.
FWIW, I took out the spare tire first, which provides a little more room to work. I removed the strut bolts first, then removed the bottom 2 screws for bushing brackets. I loosened the top ones as far as possible then removed one and the other with one had while holding the bar with the other.
Putting the new one was a bit harder. After lubricating the bushings I set the bar on top of a little step stool, like kids make in boy scouts. This gets it within about 3 inches of where it needs to be. I then raised one side and got a screw started in the upper bushing bracket on the left side.
Once that was in, I raised the right side and propped a couple of short pieces of 2X4 underneath the bar and got it very close to level. That made it much easier to get the screws started on the right.
After getting all 4 screws in the brackets, I left them loose and installed the strut bolts and torqued them to spec. Lastly I torqued the bracket bolts to spec.
I took it for about a 20 mile loop in a rural area with lots of curves and uneven pavement. I did this for two reasons; one to see how it handled and two, to see if it loosened any of the hardware.
When I got back, I used my torque wrench on everything again, One of the track bolts moved a little but the strut bolts needed about a half turn or more, which was surprising. This is why I'm thinking the thread locker belongs there.
I am taking it out today and will check it again afterwards. If still a lot of movement, I'll either take off the nuts and add thread lock or maybe install a jam nut since there is plenty of bolt left.
Ogsarg is offline   Reply With Quote
Old 04-27-2014, 01:22 PM   #168
2012 Solera
On re-torquing the bolts, see posts ~127 through ~130 in this thread. I think you have to re-do the Loctite if they turn at all. Loctite is readily available at most auto parts stores.
On my 2012 Solera, the shackles were wide relative to the Hellwig bar ends. I put spacers (washers) between the bar and the shackles; alternative was to collapse the shackles down to the width of the bar ends by tightening the bolts. This may be why your shackle bolts seemed to loosen up. As I remember, the shackle nuts are a type that don't loosen. I believe the Loctite is for the bracket bolts.
Sorry to hear of your injury. Take care -
Jim
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 04-27-2014, 05:02 PM   #169
Well I ordered my Hellwig 7254 Rear Sway bay from Leaf Springs, Helper Springs and Suspension Parts | SD Truck Springs cost $153.95 shipped to the door. That is with a $10 off onsite coupon. Shipping seemed a little slow about getting out the door but did arrive in the free shipping time frame. After I ordered I made a trip to TX with some cross winds, planning a trip later this month to MT. so I should get to see it there is any difference. Hope so!
My install was about the same as others have stated, other than I used two of the OEM bolts (one on each side) in the bottom holes to start with then after getting the top cap bolts in removed the OEM bolts and installed the bottom cap bolts. The long OEM bolts were just easier to start than the short cap bolts.
pinkstonj is offline   Reply With Quote
Old 04-27-2014, 07:06 PM   #170
I found out from Hellwig that the proper sway bar for the 2014 FR 24R is the 7254. I was glad to hear that and purchased the bar from Amazon for $154 with free shipping. I am pleased with that and hope to get the bar installed in the next week or two with the help of my brother in law. He possesses more skills and tools than I. I appreciate all the tips and accounts of how this trick or that one worked for each of you. It all helps. Many thanks.
Rich H.
[/SIGPIC]
Solera 24R - 2014
Life is Good - All is Well
