Old 04-27-2014, 07:11 PM   #171
Today we drove over to Monterey for a walk along the ocean. About 100 miles RT. Checked all the bolts with the torque wrench again and they were all tight. I'll check them again after a few more uses, but I'm guessing they won't move.
Ogsarg is offline   Reply With Quote
Old 05-06-2014, 07:59 AM   #172
Side by Side photo comparison. The Hellwig is almost twice the thickness.
mphair is offline   Reply With Quote
Old 05-10-2014, 10:08 PM   #173
Just installed my Hellwig sway bar today. I like the ride a lot better. I did notice one thing odd though- the end link brackets seemed too big for the bar. The stock bar measured 4 cm wide while the Hellwig bushings measured 3.5cm leaving a gap in the end links.
I ended up using washers on the sides of the bushings to take up the extra space. Has anyone else had this experience? Anything to be concerned about? Should I take the washers out? I noticed a pop when I pulled in the driveway, but everything looked normal when I looked at it.
Sprintboy is offline   Reply With Quote
Old 05-10-2014, 10:17 PM   #174
2012 Solera
Same experience with wide shackles - also used washers - see my post #168 in this thread. No issues with washers over 5000+ miles.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 05-11-2014, 07:29 AM   #175
Good to know - thanks!
Old 05-13-2014, 09:47 AM   #176
Rear Sway Bar
Does anyone know if the model number that's been discussed here will work for a 2015 Solera 24R? The Hellwig product site doesn't go that new. Thanks in advance for any info.
The Nutter Family
2015 Solera 24R
knutter is offline   Reply With Quote
Old 05-13-2014, 12:46 PM   #177
2012 Solera
As I replied to an earlier post, I have a 2012 Sprinter so can't answer your question. Suggest you contact Hellwig directly - they were quite responsive when I encountered a bolt issue with my sway bar. Contact Us | Hellwig Products
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 05-13-2014, 12:49 PM   #178
GM
bclemens's Avatar
Just remember that the year of the coach is not necessarily the year of the chassis. It's the year of the chassis that counts for this application.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 05-15-2014, 01:36 PM   #179
If memory serves me, the 10th position in your vin# designates the chassis year. Further I believe that the letter "C" = 2012 model year, So, "D" would be 2013, and so on. Let us know if that makes sense for your chassis mfg. date.
Old 05-21-2014, 01:03 PM   #180
The Helwig bar is the right one for the 2014-24R MB 3500. Fit just fine. Improved the stability a bundle. Love the improvement.
Rich H.
[/SIGPIC]
Solera 24R - 2014
Life is Good - All is Well
richhop25 is offline   Reply With Quote
