Old 08-31-2014, 10:24 AM   #221
I finally got around to check out the sway bar in more detail. I removed one of the Helwig supplied brackets and noticed that there were signs that the bracket was sliding up and down when it shouldn't. I decided to re torque the bracket bolts to 65 ft/lbs.
This worked, no more clunk!
mphair is offline   Reply With Quote
Old 08-31-2014, 06:41 PM   #222
Well that's good news. I haven't had any issues, but I know where to look if I do. Thank you. I applied a lot of loctite to the bolts and perhaps that will help.
Safe travels,
Jcinca
jcinca is offline   Reply With Quote
Old 08-31-2014, 07:08 PM   #223
Needs Help
I just got back from 9500 miles traveling to alaska and home. Plenty of gravel and lumpy roads. Never a sound from my hellwig. I installed with the two washers on each side.
2014 Forest River Solera 24S
Living_The_Dream is offline   Reply With Quote
Old 08-31-2014, 08:07 PM   #224
Well you certainly gave it the test. It sounds like mphair noise was coming from the bolt up brackets and noted they showed some wear from movement. He increased the torque to the bolts and sounds like problem solved. This may be the fix for those folks who had the noise issues.
Old 09-01-2014, 03:29 PM   #225
Mphair previously posted: "I finally got around to check out the sway bar in more detail. I removed one of the Helwig supplied brackets and noticed that there were signs that the bracket was sliding up and down when it shouldn't. I decided to re torque the bracket bolts to 65 ft/lbs."
Did you use a 19mm hex or a different size? I want to retorque but want to get the correct size first.
David100 is offline   Reply With Quote
Old 11-17-2014, 06:04 AM   #226
After the Hellwig installation, I have driven over 15,000 miles without a hiccup. Have not had to re-torque or do any other maintenance. I am very please to say the least. Like Taylorsgo said" I couldn't believe the difference it made - maybe the best mod I've ever done in terms of cost vs. benefit. Highly recommended for those who haven't done this yet. "
Capt Dan
CaptDan is offline   Reply With Quote
Old 11-17-2014, 07:13 AM   #227
Just wanted to add my more limited (at least mileage wise) experience compared to those of CaptDan and others. I also have had no noise or functional problems at all with the Hellwig anti-sway bar.
Installed over a year ago and after around 6,000 miles, the road handling benefits (especially under high wind conditions in southwest U.S.), have made it a more than worthwhile investment. My stress levels when when driving in inclement weather are much reduced.
Chris Weller is offline   Reply With Quote
Old 11-21-2014, 09:18 PM   #228
Installed mine last spring for the trip back to KC from Florida. Made a huge difference in the handling and gave it a lot more stability. Prior to that it was all over the road in the wind or when passing a truck. I also put heavy duty shocks on it and new spacers in the front springs. Supposedly adds a 1000 pounds to the weight limit, Really gald I did it,
sonny is offline   Reply With Quote
Old 11-22-2014, 08:47 AM   #229
sonny -- I've been thinking about some adds to the suspension for better weight control and handling in addition to the sway bar. Curious what you did specifically.
My thinking also includes the possibility of adding a couple inches to the clearance in the rear to help the jacks clear driveways and such. Did you gain any clearance?
Has anyone else added something to add clearance in the rear?
Rich H.
[/SIGPIC]
Solera 24R - 2014
Life is Good - All is Well
richhop25 is offline   Reply With Quote
Old 11-30-2014, 09:02 AM   #230
Koni Shocks
Purchased the Helwig sway bar and added Koni FDS rear shocks and spacers on front. Huge improvement in handling greatly reducing side sway and rocking. Debated on buying the more expensive Koni shocks, but after driving on a trip worth every penny. Best option one can do with Solera 24R.
jlewis3323 is offline   Reply With Quote
