Old 05-20-2015, 03:20 PM   #341
Aztrx450r's Avatar
Thanks. PM sent
Aztrx450r is offline   Reply With Quote
Old 05-21-2015, 09:13 AM   #342
Class C Representative
Joshua Cavitt's Avatar
Aztrx450r I did not get PM from you last night.
Joshua Cavitt is offline   Reply With Quote
Old 05-21-2015, 11:41 AM   #343
Robert Mayberry
Hello,
I've been getting the "big bang" also. Stopped at my dealer and they said nothing was wrong. I contacted Hellwig and they said I need to grease the D bushings. Will let you know how this works. My bangs have been quite bad.
Bob
San Francisco
2011 Solera/2010 chassis
robertmayberry is offline   Reply With Quote
Old 05-21-2015, 03:46 PM   #344
GM
bclemens's Avatar
Or flip the bar over? Seems like someone here determined there was a small raised area or nub that is hard to notice, but the bar may not be two sided.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 05-21-2015, 06:02 PM   #345
Mikegjax's Avatar
Originally Posted by robertmayberry View Post
Hello,
Bob
San Francisco
On initial installation I also got the clunk. I did a little aggressive cornering in left and right turns which seemed to allow the bar to center itself. After that no more clunk. That is also assuming the "D" brackets are proper greased and the slight dip in the bar is facing down toward the ground.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 06-13-2015, 09:46 AM   #346
Just installed (2 ea) Bilstein 24-177702 4600 Series 46mm Monotube Rear Shock Absorbers. Took the 2013 Solera "S" for a spin around the block. The Helwig made the most difference in ride control. For those RV'ers that do not have/installed the Helwig sway bar is a "MUST BUY!" The Bilsteins greatly reduced the rocking motion and made a slight improvement in the ride. Anything to improve the ride I would buy, more later. GLTA
CaptDan
PS: Maybe Sumo's next when the price goes down!!
CaptDan is offline   Reply With Quote
Old 06-13-2015, 11:45 AM   #347
Hey Capt!
Did you do the installation yourself? If so, can you describe the process?
Thanks!
Dave
DaveJordan is offline   Reply With Quote
Old 06-13-2015, 07:11 PM   #348
Phinias's Avatar
Bilsteins,Hellwig, now you need Sumo Springs and the job is complets. I had all three installed at a total of one hundred and forty bucks
Phinias is offline   Reply With Quote
Old 06-13-2015, 07:11 PM   #349
Phinias's Avatar
that 140 was labor
Old 06-13-2015, 09:52 PM   #350
Just do it. You will never regret spending the $200 for it when driving thru crosswinds or just around town.
barnbnb is offline   Reply With Quote
