Old 06-14-2015, 08:21 PM   #351
CharSolera's Avatar
Phinias (or someone else who didn't install these themselves), who installed them for you (if it wasn't a private party/friend). After a weekend in the woods and some pretty fierce rockin' when I traveled over the potholes in the dirt road, I am upgrading. But, this isn't the sort of job I can do. Who (company) installs these types of items (Helwig, Bilstein or Konis) on a motorhome?? Thank you!
Charlene
and catpanions, Purrl & Lucy Lu
2014 Solera 24S
CharSolera is offline   Reply With Quote
Old 06-15-2015, 06:54 AM   #352
FIVE2MH's Avatar
CharSolera - Hellwig's website has a link which enables you to locate a dealer in your area that sells/installs the sway bar. It cost us almost $400, but we couldn't do the installation either. For us, it was money well spent...
2015 Forester MBS 2401R
No Toad
FIVE2MH is offline   Reply With Quote
Old 06-15-2015, 07:28 AM   #353
CharSolera's Avatar
Thank you, Five2mh. I'll start the search there.
Charlene
2014 Solera 24S
Old 06-15-2015, 12:47 PM   #354
Robert Mayberry
Wish I'd never done this. They used to make a big bang when you go over a dip. So I had the dealer reinstall them on with the dip down and grease the D bushings.
The big bang is gone. Now I have a snapping/popping sound on every corner, every little dip and every little rough patch in the road. Its really irritating!
Bob
San Francisco
robertmayberry is offline   Reply With Quote
Old 06-15-2015, 03:39 PM   #355
Phinias's Avatar
Hmmmmm.....mine is perfect
Phinias is offline   Reply With Quote
Old 06-28-2015, 11:38 AM   #356
devilsquid's Avatar
Bob
San Francisco
Good morning All, I too have had this popping noise from the moment that I installed the Hellwig. It began with an occasional loud lunk/pop (by lunk I mean it sounded like a torqued rod letting loose or adjusting) and it has progressed to every time I drive into a driveway or any other thing that causes a sway just like Bob. I re-torqued the D clamps to 65ft/lbs had lubed those clamps on installation and the popping has only gotten worse. I did not check for the dip up or down on my initial installation and will when I take everything apart for a start over. I also used the washers to fill the gap in the shackle. I plan to use the assembly compound on the D-clamps, make sure the dip is down, torque the D-clamp bolts to 50 ft/lbs and the shackle bolts to 65ft/lbs (I think I read that the shackle bolts were to ones to torque to 65 and not the D-clamp bolts) my question is has anyone greased the shackle bolt as it passes through the bearing? It is very disconcerting to have everyone in a gas station turn around and look as I snap and pop my way to a pump. Not a good external marketing experience for a very fine motorhome. If anyone has any other possible solutions please let all of us who have this problem know what it is...I'm to a point of trying almost anything (putting the original back on is not an option, it's long gone). Thanks
devilsquid is offline   Reply With Quote
Old 06-28-2015, 01:10 PM   #357
Has anyone contacted Hellwig about the noises?
I contacted them to ask whether the dip went up or down. They told me either way works, and makes no difference in the performance. I was satisfied with their tech support, and wonder if anyone bothered to ask them what might be causing the noises.
I have no noises whatsoever. I am very pleased with the sway bar, and how much it has improved handling.
Hope you get your issue solved. Those little things can be the most annoying...
tommyb is offline   Reply With Quote
Old 06-28-2015, 01:29 PM   #358
2012 Solera
Hellwig Sway Bar Issue
I was an "early adopter" I think - installed my Hellwig in July 2013. I had been quite satisfied - initially received bolts with incorrect thread, but Hellwig sent the correct bolts fairly quickly. I did not have a clunking issue - after reading about the issue here, I did notice an occasional noise, but was never sure it was sway bar related.
However - when I took my vehicle in last week for alignment, wheel balance and rotation the shop called me to tell me one of the sway bar brackets was broken and the sway bar was essentially hanging loose on one side - doing nothing. I know on our recent trip to Banff, Glacier NP and Rocky Mountain NP we encountered some VERY bad road construction bypasses in Montana - not sure if this is where the failure occurred. I had the service place re-install the original sway bar and brackets (I kept everything) and have a message in to Hellwig - awaiting their response.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 06-28-2015, 02:06 PM   #359
Mikegjax's Avatar
I torqued mine to 40 lbs. Just because I could not see the 35 lb mark. Over torquing will not get you anything other than weaking the fasteners and brackets IMO. I hand the clunk until I did some aggressive cornering in both directions after initial installation. Clunk stopped after bar centers itself.
2014 Solera 24R
USN Retired
Mikegjax is online now   Reply With Quote
Old 06-28-2015, 03:14 PM   #360
devilsquid's Avatar
tommyb,Thank you for your input. I went out to check the orientation of my sway bar and it appears that my sway bar is installed with the bent section of the bar pointed up ( so opposite to what other posters are saying is correct). Way back in my early days I flew as enlisted crew on Marine helicopters and remember the Boeing Techreps telling us that we could not do the fix the that way...too bad we already knew it worked by performing that bit of "field" maintenance everyday only it was easier, faster and we never lost a bird because of it. It looks like there shouldn't be any difference in how the bar functions due to it's orientation but until proven otherwise down is right, up is wrong (at least it will eliminate one of the confounding factors). I wonder how many of us who have the popping noise had their sway bar mounted upside down?
