Old 07-20-2013, 04:11 PM   #61
Displaced2's Avatar
Know of any installation on Ford chassis and results?
Displaced2 is offline   Reply With Quote
Old 07-20-2013, 04:15 PM   #62
Taylorgso's Avatar
Don't know of one personally, but Hellwig makes one to fit. - check their website. Should help any chassis vs the stock sway bar.
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
Taylorgso is offline   Reply With Quote
Old 07-20-2013, 05:19 PM   #63
Look at How To Install RV Anti-Sway Bars - Part 1 - YouTube for part I and How To Install RV Anti-Sway Bars - Part 2 - YouTube for part II.
CaptDan is offline   Reply With Quote
Old 07-26-2013, 06:04 PM   #64
Caution mounting bolts were not correct pitch
Just install my rear bar. The 4 socket headed cap screws were not the correct pitch. They were 1.25 mm not 1.5 mm as needed for my 2012 MB chassis. So I had to purchase new bolts. Good news new sway bar is great improved. Now I need to test in a cross wind.
13larry is offline   Reply With Quote
Old 07-26-2013, 06:56 PM   #65
2012 Solera
X2 on wrong thread on supplied bolts. Helwig replaced mine - used the contact e-mail link on their website.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 07-26-2013, 07:32 PM   #66
Taylorgso's Avatar
Cross wind is the "proof of the pudding" - you'll be amazed at the difference. Curious why some of these come with wrong thread bolts - wonder if MB has changed the thread count somewhere in there product history. Mine were threaded correctly, and installed without any snafu at all.
Greensboro, NC
Old 07-26-2013, 07:37 PM   #67
2012 Solera
Per Voicemail from Helwig, their vendor supplied them the wrong bolts.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 07-26-2013, 07:56 PM   #68
hkreck's Avatar
When I installed mine I got one cross threaded had to put one of the old bolts back in to rethread it, worked out in the end. While going through Neb. last week I could feel the wind against the MH but not like before. BIG improvement.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 07-28-2013, 06:25 PM   #69
Sandiegodoug's Avatar
We got the wrong bolts too. Had to put the old one back on but the shop setting up my rubicon jeep for towing came up with a solution since I was leaving for a trip up the coast the next day.
Big difference and really improved the handling on curvy mountain roads
Sandiegodoug is offline   Reply With Quote
Old 07-29-2013, 08:29 AM   #70
fortbud's Avatar
I installed mine about a week ago and it works great. However, I had to make a run to Ace Hardware for the correct bolts. Helwig sent three of the round hex head bolts with too tight of pattern and one standard head bolt with the correct pattern. I contacted Hellwig last week and they have said they are investigating and haven't heard back yet.
fortbud is offline   Reply With Quote
