Old 08-25-2015, 09:48 PM   #11
Pod2Vibe's Avatar
Originally Posted by bclemens View Post
Aware of what problem? Most of the Hellwig's were dealer or customer installed, they just started installing at the factory fairly recently. One post above says they have a factory installed bar and no issues. One below says cross threaded. The clunking seems to be a small percentage...certainly not the majority.
Yup, for sure, no clunks here - Customer installed.
Pod2Vibe
2015 Solera MBS 24R - Hellwig/Sumo Equipped
TOAD: 2014 Fiat 500 Abarth
(Sold the Vibe 6506)
Pod2Vibe is offline   Reply With Quote
Old 08-25-2015, 09:50 PM   #12
Vince and Charlette's Avatar
Ran into a similar clunking when I did the CHF on my 2015 Georgetown. Turns out that moving to the aft hole in the sway bar raises the front of the bar so high that it contacts the frame...most evident in turns. Big rig alignment shop said that mine was the third Georgetown CHF that he had to undo this year. Just yesterday, I took delivery of a new Roadmaster anti-sway bar (1139-140). It's really beafy compared to the Hellwig. It costs more, but it is heavier and comes with brackets and bushings significantly larger and stronger than the Hellwig. On the other hand, I hear reports that both are a big improvement over the OEM.
2018 Berkshire 38A
Vince and Charlette is offline   Reply With Quote
Old 11-10-2016, 03:37 PM   #13
MNtraveler's Avatar
Hellwig Sway Bar Clunk/Noise Problem Identified And Fixed FINALLY!
bclemens - I don't think we have a Helwig, but the suspension clunks a lot during slow speed maneuvers. Took it to the MB dealer and they could not find anything wrong with the MB supplied equipment and also said they don't deal with issues caused by putting the heavy box onto the MB frame. The FR dealer doesn't deal with frame and suspension issues. So?
Land of 10,000 Lakes
2016 Forester MBS 2401R
Nights camped 2016: 32; RV to date: 35
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 11-12-2016, 09:02 AM   #14
Thought about one, then thought, what if MB steps in and says, we have spec'd the sway bar as our engineers designed for the 1 ton chassis. As we all know, putting the "box" on, pushes the chassis to near limits. Then I thought, during a sway, the bar torque absorbs some, and the axle gets the rest, at the point of connection. The issue I had is, does the axle specs allow for the forces applied. The clunks are feedback to the torque forces being applied. One will never know if the heavy duty sway bars are effecting design limits, unless reports surface of axle failure start to pop up. The general engineering concept is to design it for about three times the expected force apllied in these types of application. But, as one poster has said, the "not my problem" scenario has surfaced. I'm on the sideline on this one.
Old 11-14-2016, 06:39 AM   #15
Hey kickin'. That exactly what I've been noodling for that past year. I put the heavy duty sumo springs suspension parts on, which quelled the sway wonderfully, but tightened up the shock absorption considerably. Since then I've wondered about the load placed on the axle by the bump stop replacements and the structural issues of the rear of the motorhome itself with increased harshness of the ride. We've had no issues over the 45,000 km travelled since installation. But it's something I think about.
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
backdoctor is offline   Reply With Quote
Old 11-14-2016, 08:49 AM   #16
GM
bclemens's Avatar
I haven't seen any "clunking" reports on anything that didn't have the sway bar. You say you "think", can you confirm? The Mercedes bar is black...If I'm not mistaken, the Helwig is dark gray with a textured finish on it.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
sway
