Old 04-20-2014, 02:52 PM   #11
Originally Posted by hkreck View Post
I'm not concerned about it, just responding to danielto98's posting.
That's who my post was directed to. Sorry.
Old 04-20-2014, 03:11 PM   #12
hkreck's Avatar
That's OK it is hard to keep track on the postings. Happy Camping. :-}
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 04-21-2014, 09:22 AM   #13
I saw the wood exposed and also concerned if some roddent crawl into those holes and ends up dead inside the slide. it will be hard to deal with that.
Forest River used a lot of foam insulation to seal a lot of opening. I am just surprised that there are no plugs for these four holes.
It is going to tough the keep the plugs in place becuse off the weather strip. I may use aluminum to cover those holes up after the warranty expired.
Thank you all for the replies.
Daniel
danielto98 is offline   Reply With Quote
Old 04-21-2014, 09:30 AM   #14
hkreck's Avatar
Daniel
Can you post a picture of the holes so we can see what your seeing?
Henry & Tena
2013 Solera 24S
The Great Escape
Old 04-21-2014, 09:34 AM   #15
GM
bclemens's Avatar
Yes, what he said. Factory rep responding as requested. Without pictures I can only assume that the slide was installed, maybe it shifted, needed adjustment and new holes were drilled? Does it look like that? Plastic flat plug would work if its a concern. Expanding foam and then shave off the bottom when it dries.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 04-21-2014, 10:09 AM   #16
hkreck's Avatar
OK posting #5 is the picture I posted showing the factory installed bolts in the slide. As bclemens is stating I'd just put some foam or plastic plugs up in the holes.
Henry & Tena
2013 Solera 24S
The Great Escape
Old 04-21-2014, 10:16 AM   #17
GM
bclemens's Avatar
I thought he was saying he had "extra holes" with no bolt in them?
If there are extra holes, then I would assume a slide adjustment was made...slide ram unbolted, realigned, new holes drilled. Voila. If that's not the case...I don't have much to add.
slide, slide out
