Old 07-19-2014, 09:54 AM   #11
hkreck's Avatar
I just got the old horn replaced at MB the horn was bad and they replaced the relay also. I'm looking at putting the new horns on in the next couple of days. Will keep you advised.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 07-19-2014, 09:56 AM   #12
Thanks Henry. I look forward to your findings. I hope to replace my wimp horn also and appreciate any guidance.
Rich H.
[/SIGPIC]
Solera 24R - 2014
Life is Good - All is Well
richhop25 is offline   Reply With Quote
Old 07-19-2014, 11:55 AM   #13
hkreck's Avatar
richhop25, OK, I replace the factory horn with a Wolo model 225-2T duel horn from JCWhitney, the horn is louder and even the DW stated she could hear it better from inside the house. One thing that I found to be strange is the ignition switch has to be in the on position for the horn to work. Found this to be true with both the factory and after market horn. Any case I think if you go on a site and give the make and model for your vehicle you'll find a list of horns for the sprinters that you can choose from. This one stated to make sure to have a 15 amp fuse to protect the system. Good luck.
Henry & Tena
2013 Solera 24S
The Great Escape
