Old 11-11-2014, 07:17 PM   #1
Hot Water Heater Rod
I drained my hot water heater this evening in preparation for a short winterization here in Northern Virginia. Leaving for west coast end of next week. Anyone with some experience in how the rod should look, your assistance is appreciated (see attached photos). I just purchased this 2014 Solera from McGeorge (Richmond, VA) in June, 2014. Not sure if the rod should look this eaten-up in such a short period of time.
I would prefer not to take this back to McGeorge..This is another story, but I am still waiting on them to approve replacing the hydralic jack motor and resevoir that burned-up because the ground was grounded to one of the relay solenoids (over a month ago). Still waiting on getting reimbursed for $380.00 for the cost of roadside labor.
Seems like i could just purchase a new water heater water release rod. Thoughts?
Thanks, Mike
ID:	66258   Click image for larger version
ID:	66259   Click image for larger version
ID:	66260   Click image for larger version
BLK-9 is offline   Reply With Quote
Old 11-11-2014, 07:21 PM   #2
caper's Avatar
The cost of a new rod is only about $18 this is cheap insurance for the water heater. If you are in doubt replaced the rod.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 11-11-2014, 07:27 PM   #3
Your rod is just fine. Google it and you'll find pics of worse ones than yours. Mine just finished its 3rd season and is about half gone.
2011 Traverse LT, 3.6L, FWD
Old 11-11-2014, 07:27 PM   #4
wmtire's Avatar
In the FAQ section here on the forums, there is an anode rod chart in the water heater section that shows the different stages. Yours is fine for some more action, and it normally starts deteriorating from the end your has.
Anode facts and FAQs
I just posted this in another forum and this may help you also:
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 11-11-2014, 07:27 PM   #5
hkreck's Avatar
Considering it's as bad as it is I'd look at replacing it. It does seem strange that it just at the one end. The rods I've had normally corrode along the entire rod were your is just in the treaded end. Also was this purchase new or used?
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 11-11-2014, 07:28 PM   #6
Shinny's Avatar
Mine isn't that bad, but it's close after only 5 months and only 23 nights camped. I drained it twice though. I would replace it. They're only about $15-20.
2015 Sierra 32QBBS-23 nights camped since the end of June 2014
2015-sorry to say only 11 nights so far, more to come though
Shinny is offline   Reply With Quote
Old 11-11-2014, 07:29 PM   #7
Mr. Dan's Avatar
Do a search for anode rod. There are several threads on anode rods, some as recent as yesterday. The rods sacrifice themselves for the good of your water heater.
See the pic of mine I removed this afternoon. It is still quite usable.
Name:	ImageUploadedByForest River Forums1415755729.010212.jpg
Sent (I think)
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 11-11-2014, 07:30 PM   #8
mckirby50's Avatar
Mine looked way worse the first time I changed it! The dealer said it was ok, but I changed it anyway. I pulled mine today and it looked worse than yours, I may not change it this time. I get quite a bit of calcium deposits out whenever I drain it.
mckirby50 is offline   Reply With Quote
Old 11-11-2014, 07:31 PM   #9
WFD
Proper term is an anode rod...it is a sacrificial rod and is designed to do just what it is doing...it will break down with time...thus the term sacrificial rod. Yours is fine still, probably good for another season, maybe more! All depends on the water.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 11-11-2014, 07:32 PM   #10
I purchased it new.
hot water, water heater, water, heater
