10-14-2011, 04:45 PM
How and where to install an Inverter in Solera MH..
My advise is, iIf you have two Batteries under the steps you can install a 1000 W Inverter.
It is very useful for so many things, like making coffee, toast, TV/DVD etc., while traveling to your destination,
A 1000 W inverter cost between $ 50 -$75 and some come with about a 6 Ft 10 Gage ready cables. Or you can buy ready cables in any auto shop. It is important to have the shortest distance the Battery and the Inverter. In a 1000 W inverter you can plug in two appliances.
I found the best location on the left side (going up on the stair) all the to the edge between the fume detector and bottom of the extension table, to the edge of the counter. Drill a whole in the side of the counter, where the wire will connect to the inverter. Take out the bottom drawer and drill a whole through the floor. Next; remove the step over the battery. In the middle of battery compartment is an already a hole to take the cable out, way to the already drilled holes. Push the cables through both holes and hook it up to the inverter. Next is to hook the positive (RED) and negative (black) cable to the negative battery pole, following the positive to the positive battery pole. Make sure to seal the floor holes so no water comes in to the MH.
Good luck
10-15-2011, 05:42 PM
too fast turbo sled
1000 watt inverter is pretty small ......
about 9 amps or so ?
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
10-17-2011, 10:22 AM
Don't forget to fuse the inverter. Not doing that is VERY dangerous as the cables provide access to unlimited power (as much as the battery holds).
Plus a switch for on/off should be there. You don't want the inverter drain your battery while sitting in storage (and they have a pretty good standby consumption).
Reiner
2011 Solera
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 615 |
| 110 members and 505 guests |
| 4bnabird, Al Fresco, backin15, Barney1, biggie, biken201, bikendan, Bill m, Bill_C, bradyashton, Cafjackracing, Canuck_Doug, caper, case1175, cbj, CC Steve, ccyake, chadvc, COcamper, cpope84, crazn, cyclepuck, dashonthedash, dasimser, datadr, daw592, dawg82, demoore, DGrissom, Dodge Guy, DonG, donn, dunnnc, dware1962, ERRT, etbt1216, fast murray, feerobk, Fire Instructor, Fitchy, FreedomTracker, frfan, GASPEDDLER, gator man, Go Camping, Goomph, herk7769, hockey11, Iggy, imabmwnut, ironj, jd-ford-hd, JDWeir, jimh, jmlocke, Jnied, Jo54, JoeR, JoeyO, jonnys_walkers, jrat, jsutherl, KKapa, Kman9936, KRS, kvn4th, kz08h5, lami, lcsolutions, LeadPoop, lowbubba, low_flyer, lurch, MikeFletcher24, Mpwelch50, Msaunders, mtofell, N3HCP, Namchief, newtsx3, nightcrawler, OffPavement, pappcam, pbrackney, pchrcane65, polkatronron, PrairieBoy, QDog, racerx, Rebel702, ret2006, RichardE, robert elling, Rsgtivr6, sandys, seatosea, Senor, snjparham, Sockman, softwarejoe, stevengb, tabkld93, Terier, Trailblazer, Triguy, troyt, unhcharger25, wayne anthony, Whiteknight, william.migues |
| Most users ever online was 996, 05-22-2012 at 11:04 AM. |
